Question about Franklin Heating & Cooling
Value montgomery ward franklin heater ymt 21017r
My brother used this heater at his ranch i just had it installed as a chimmeny and it smokes is it because i left the doors open or is it because i need the outside part to be higher so that it could **** up the smoke to the top of the house
SOURCE: Delonghi "the incredible heat machine" started smoking
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Papou1
Posted on Feb 10, 2008
SRF518
  • 232 Answers
SOURCE: WE need parts for our Montgomery Ward wall heater
what kind of parts?
Posted on Oct 16, 2009
  • 4102 Answers
SOURCE: it lights like its new but it stinks and smokes like you wouldnt
hi, have you left it on for about 10 to 14 minutes as you may just find that their is a build up of grime that needs burning off first and you should find the smell and smoke will stop over time.
So just put it somewhere where the smell and smoke wont harm anyone and then just leave it on sometimes they can take ages to burn off all the dust and grime that has built up expecily if it has been stored somewhere dusty and damp.
Just give it a good 20 to 30 min and then you should find the smell and smoke will slow down and eventually stop.
Could i just ask is it giving off any heat at all or just smoke and smell?
we use to have one of these when we had a car repair workshop that had no heater it was just like a big garage to fit about 10 cars in so we used one of those and found them pretty good.
Give it a good run and let me know what happens from what i can also remember their was no dials on our neither it was just a case of plugging it in and then it would start and give off heat and plenty at that
Let me know how you get on or if you need further assistance ok
Posted on Dec 19, 2009
SOURCE: I need to know the correct size for the auger belt
I'm not sure which belt is which, but one belt is 3/8" x 29.0" long and the other one is 3/8" x 38" long
Posted on Dec 24, 2009
  • 4736 Answers
SOURCE: I have a Montgomery Ward
Your wood burning heater has been out of manufacture for some years now and OEM parts are almost non-extent. However, if it's a damper door or something like that, I would suggest taking the part(s) with you and visiting a wood stove dealer in your area. Some parts are fairly generic and can be interchanged. I believe that Warm Morning (Martin Industries, who is no longer in business) manufactured the stoves for Montgomery Ward. If you can find some Warm Morning parts, you may be in business.
Good luck in your search.
Posted on Apr 17, 2011
Manual for wards hot water heater
1) Copy following links to identify gas control valve, troubleshoot resources, and gas water heater installation
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Unsure which manufacture makes/made Wards water heater, or how old your unit is.
Three manufactures make most brands tank-type water heaters, and generic manual basically covers all brands.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) Add comment Feb 2013, and say what you are doing.
Feb 03, 2013 | Water Heaters
I have a Montgomery Ward Wood Burning Heater (model # 81-SJW-56212). Where can I go to get replacement parts?
Apr 17, 2011 | Montgomery Ward (223600UP) Heater
The heater will not stay burning
Depending on it's age, it's probably the Thermocouple going bad. Or you may have an insect nest inside the screen housing, around the pilot assembly, that needs to be removed. If you need to replace the thermocouple, I suspect the heater was manufactured for Montgomery Ward by Uniflame or Blue Rhino. Either should fit your heater.
Apr 02, 2011 | Montgomery Ward (223600UP) Heater
How can I get the specs on a Montgomery Wards Heavy duty 1000 water heater? We are trying to find out how many Amps it draws.
look on the internet for ohms law. when you find it you can use this formula to figure out what you need.
Mar 13, 2011 | Montgomery Ward Heating & Cooling
I have an old montgomert ward space heater mod 313 and would like to be able to us it, but when it is running you can not stay in the same room.\r\nThe fumes are terrible. I had to adjust the air to reduce...
Sounds like your "old Montgomery Ward Space Heater" has given up the ghost. Frankly, it's time to replace it. Even under the best conditions (even with routine maintainence) they don't last forever. Continuing to try to use it, becomes a safety & health issue.
Jan 28, 2011 | Montgomery Ward (223600UP) Heater
I have a Montgomery Ward Snow Thrower Model 495A. A rope got caught in the auger. Now the motor runs but the auger will not turn. Any idea what was broken and where I can get parts to fix it?
I have an older Montgomery Ward Snow Thrower model No. TM0-35286A and I'm having a hard time finding parts for it. The tiller just stopped working so I'm thinking the worm-gear is shot, but I can't even find the part on-line...Can you help?
Dec 10, 2009 | Montgomery Ward (223600UP) Heater
Wick and manual for Montgomery Wards Windsor kerosene heater
Hi, I have a Montgomery Ward Sunheat heater. It's a dual burner enclosed type with a door on the front. The fuel tank is cylindrical and about 1 1/2 - 2 gallons. The cap has a needle valve and when turned upside down releases fuel to the burners by gravity. The whole heater itself is rectangular with louvers on the sides and top. I don't know what wicks go in this or if there are compatible replacements out there.
No 84ALO5800A is the only I.D. or Model No.
Thanks,
Jack
Nov 27, 2008 | Montgomery Ward (223600UP) Heater
Heating & Cooling Logo
24 people viewed this question
Top Franklin Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Franklin Heating and Cooling Expert? Answer questions, earn points and help others
