Question about Panasonic TH-42PZ800U Plasma TV
Black horizontal lines panasonic viera plasma
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Posted on Oct 31, 2007
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
dsacco86
  • 1077 Answers
SOURCE: what does it mean when my plasma tv turns off by
Basically when it turn itself OFF automatically all the time, the TV goes into "Protection Mode". This happens when there is a damaged circuit board inside the need to be replace and turn itself OFF to protect the other ones from being damaged.
A TV service tech will have to look at it to find out which boards need to be replace. There are about 7 different boards in your TV that would cause this problem.
Posted on Nov 02, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
  • 380 Answers
SOURCE: solid black vertical line
You could have one of three problems. One is really expensive to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went bad. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable2_bing.gif and clean it off a bit and put it back. If its still there, you have a deeper problem.
The buffer boards are located across the bottow when you take the back off. About 3 inches wide. Sometimes they are on the top as well.
Posted on Dec 06, 2009
Blue & red horizontal lines in plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 18, 2016 | Panasonic Viera TC-P50G25 50" Plasma TV
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Horizontal line of red pixels on plasma screen
Sounds like a Y-sustain board fault. For more information go to http://electronicshelponline.blogspot.com/ It has screen-shots to defective plasma displays. You can see and compare it to that of your TV's screen, and can make sure. Pull up older posts.
Nov 29, 2013 | Panasonic Viera Tc-p42g25 1080p Plasma 42...
I have a 2" black line at the top of the tv. And also smaller black lines across the middle of the tv.
Dear Jeff,
It seems like the Horizontal IC in your TV is dying. This and the Vertical IC is responsible for displaying images on your TV. (Look at your TV through your Phone Camera and you will see upward scrolling lines.This is the Horizontal IC in action.)
I would strongly advise you to get your TV repaired immediately.
Oct 19, 2012 | Panasonic VIERA TH-65PV500 65 in. Plasma...
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My Panasonic plasma TV has suddenly developed a one pixel thick horizontal black line across the screen. It is not there when the TV is switched off.
it'll not be there when tv off because dead pixels do only show when back light of screen comes on, anyway if you still have a warranty then ask for them to check it out as it sounds like you need a new screen there mate
Nov 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
There is a black line about 6 inches in just on the left hand side of the screen.
coba cek di bagian horizontal, disana ada satu elco dengan ukuran Volt tinggi sekitar 160 volt-250 Volt ( 2,2 uf/160 volt or 4,7/250Volt), kemungkinan rusak atau lemah sehingga sisi layar TV tidak penuh. juga , cek capasitor pada horizontal output.
Aug 24, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Iwas watching my panasonic plasma and the screen went green.
One of the "Y" buffer boards have failed. The buffer boards are located on the left side of the set looking from the back. There are two of them. One for the upper half of the screen, one for the lower. Disconnect and replace the one that had the blank portion of the screen.
May 20, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH-42PZ800U Plasma TV Logo
12 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
