Question about Garden
Dolmar 117 wont stay ruuning carb set 11/4 out on high and low when it fires it dies squeezing the trigger kills it
  • 124 Answers
SOURCE: Require high and low carb settings for Poulan 2050
You will find that saws of recent production allow very little if any adjustment for the consumer. The carb will either have limiters which allow you less than one turn of adjustment or they require a special tool to make the adjustment. You will need to take it to a dealer to have these adjustments made. This is your government in action protecting you from that evil pollution your chainsaw spews out.
If you are able to adjust, then gently seat each screw and open 1 full turn. This should allow the unitto start and you can adjust from there. If it will not start you probablu need carb repair or replacement or you have other problems.
Posted on May 11, 2009
nobby63
  • 10 Answers
SOURCE: chainsaw wont stay running
check crankshaft seals,maybe sucking air. most of the time the seal on the starter side. hope this helps.
Posted on Jul 09, 2009
dontbother10
  • 2220 Answers
SOURCE: sachs dolmar over oiling chain
I am not familiar with your specific saw. That said on most saws, under the clutch cover, below the clutch is an adjustment for the oil pump.
This is a Husky:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_1150183-95.pdf top right page 34 example,
On my Pioneer it is under a cap screw. HTH
Lou
You might also try here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This is a collection of professionals, amateurs, mechanics, and whole bunch of nuts. At least member has a rotary engine Sachs Dolmar.
Posted on Oct 01, 2009
  • 302 Answers
SOURCE: carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Posted on Jan 28, 2010
dontbother10
  • 2220 Answers
SOURCE: high & low carb needle settings
I would start with both the "H" and "L" needle valves at 1.5 turns CCW from lightly seated then adjust for performance as follows:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 16, 2010
Testimonial: "thanks guys&gals i used to work on all this stuff as you get older you tend to lasp onse in awhile. thanks alot mack"
Settings for mixture screws
Most Chain Saw Engines Have Three Carburetor Adjusting Screws:
1. Idle Speed/Throttle Stop - This is the adjustment that controls how much the throttle valve (butterfly) stays open when the throttle trigger is released. If this adjustment is set too low, the engine will die when the throttle trigger is released. The throttle valve (butterfly) simply cuts off the supply of combustible air/fuel and the engine stops. If this adjustment is set too high, the high idle speed will cause the centrifugal clutch to engage and the chain will run. This is a dangerous condition and should never be allowed.
2. Low Speed Fuel Adjustment (marked L on carb, this is the low speed jet)- This is the adjustment that controls the proportion of fuel in the combustible air/fuel mixture at idle speed. An adjustment that is set too rich will cause the engine to load up and die at idle speed. A mixture that is too lean will starve the engine and cause it to race or surge. An extremely lean adjustment will cause the engine to die, too.
3. High Speed Fuel Adjustment (marked H on carb, this is the high speed jet) - This is the adjustment that controls the proportion of fuel in the combustible air/fuel mixture at cutting speed. It would not be accurate to say that this is the most important setting, because all of these adjustments need to be accurate for a saw to perform its best, but this is the adjustment that determines how the saw runs in the cut. An adjustment that is set too rich will not allow the saw to reach the RPM level necessary to build maximum power. Throttle response may also be sluggish and the engine would smoke and perform poorly. A mixture that is too lean will allow the engine to reach an RPM level where bearing failure and cylinder seizure are likely. It will also lack power in the cut and tend to run very hot.
The preceding information briefly explains rich and lean running conditions. It also identifies the three adjustment screws and their function. It should be noted that some chain saws lack the high speed adjustment needle. These saws have what is called a "fixed jet" which is set from the factory. "Fixed jet" carburetors are used to prohibit the saw operator from setting the adjustment too lean and damaging the saw. Unfortunately, they also often prohibit the saw from achieving maximum performance.
Apr 11, 2016 | Garden
Dolmar 6800
The idle speed should be NOT QUITE high enough to rotate the chain when the chain lock is not engaged. There should be NO adjustment for high idle speed.
Aug 06, 2014 | Dolmar 18" Power Match Chainsaw Bar .375"...
Throttle trigger will not lock
1. Make sure dead mans handle is fully depressed
2. Squeeze throttle in
3. Push choke switch all the way down
4. Pull saw over till it fires
5. Click choke switch up one position to half choke
6. Pull over saw until it fires up, saw should start running at high rev's
7 .'blip' throttle for saw to return to tick over.
If the choke switch doesn't stay down in section '3' check chokelinkage to carb.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Got a1996 yamaha yzf 600 and it starts but its not getting gas so it shuts off new carb all the way thru
Hi, Ktatejr86 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
03 Yamaha YZF 600R wont stay running
YZF600R Forums View topic Need Help Wont stay running
Yamaha YZF600RP Owner Manual
OEM parts for Yamaha
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
Jul 30, 2012 | 1996 Yamaha YZF 600 R thunder cat
Factory carb settings for dolmar ps460 chainsaw
Try squirting a little starting fluid into the carb and try to start. If it will try to run, you have a fuel problem. Try changing the fuel filter first.
Apr 07, 2012 | Garden
Craftsman model 358.791042, gasoline weedwacker wont stay running
let it warm up first and then pull the trigger. if that doesnt work, it might be the diaphram . they are cheap.
May 10, 2010 | Garden
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
