Simpson enduro 751
Getting oil on clothing. What could be the problem
5 Suggested Answers
SOURCE: simpson enduro 751 clothes washing machine
Befit Sports are the suppliers for motocross gear, enduro clothing, ATV apparel, dirt-bike clothes and moto gloves.
Visit our web site http://www.befitsports.biz
or
contact us at info@befitsports.biz
Posted on Sep 03, 2010
SOURCE: We have a Simpson Enduro 751 washing machine and
hi have you found an answer because ours does the same thing
Posted on Sep 18, 2010
tunde007
  • 2382 Answers
SOURCE: Simpson Enduro 752, when spin
Hi, one of the most common problems with the washers is that the shock absorbers that hold the tub in place can break. These shock absorbers steady the tub during the wash and spin cycles. It is when the spin is happening that they take the worst beating. It is also during the spin cycle that the breakage will be most evident. If your load is even a little bit out of balance and the shocks are broken, your machine may dance all over the floor and sound like an airplane about to take off. The tub will flounder around uncontrollably and the clothing will come out very wet because of the tubs inability to maintain the spin speed needed to wring out the water.
You need to replace shocks....
Posted on Mar 15, 2011
FitzOriginal
  • 842 Answers
SOURCE: My Simpson Enduro 701 does
Looks like you have 2 problems here. The draining issue is probably a blocked pump, but the ripping is far more serious as it's usually associated with garments getting caught between the inner drum and the outer drum. THIS is usually the result of faulty main bearings, which may, I'm sorry to say, be fatal. I have attached some generic advice below. Hope it heps you pinpoint the problems:
The problem you describe with clothes being ripped is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about"and trap clothing when it does.
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed.
If the bearings are bad enough then other symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open.
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about £20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
Turning to the issue with drain problems and wet garments:
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Posted on Jul 11, 2011
Testimonial: "Thanks for the advice, it's a fairly old machine so will probably just buy a new one. Cheers"
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson enduro 751
If your television is leaking, I suggest throwing it away.
Oct 23, 2013 | Televison & Video
Oil on cloths after wash
Simpson washing machines are known for this, The seal in to top of the gearbox fails which allows water to enter the gearbox, this forces the grease out of the gearbox into the machine, The fix is an expensive gearbox swap.
Mar 11, 2012 | Simpson Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Simpson enduro 751 clothes washing machine
or
Apr 06, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
