Question about Pantech vega r3 IM a850l dual sim unlocked gsm phone
Mic volume microphone low volume
Hi, I have HT-1001 mic, the volume from the mic is low, any possibility increase the volume? do i need to use the external Amp?
The mike can be a mismatch with your CB A booster mike amplifier with a volume control will suffice.
Oct 25, 2012 | Hisonic Audio Players & Recorders
Micophone problem
Microphone might be in mute mode or the volume of the microphone is very low. I assume that you have inserted the jack of the Microphone in the correct port colored pink.
In Windows XP :-
Step 1. Click Start -> Control Panel -> Sounds and Audio Devices
this will open a window
Step 2. Click on the Volume tab and under Device Volume click on
Advanced tab will open the Master Volume window
Step 3. Search for the Mic Volume, if it is not there click Options ->
Properties and then check the box beside Mic Volume under
the volume controls then click OK now it will show in the
Master Volume
window.
Step 4. Then check the volume of the Mic Volume is full and there is
no check mark beside Mute.
If this doesn't solve the issue give me a feedback about the problem with much more details and the operating system you are using.
Jul 07, 2010 | Intel D845GVSR Motherboard
I plug my rode ntg-2 into the computer and record using audacity and the recording is extremely low in volume.
This mic needs phantom power to operate. Best bet, go and buy a USB mic pre, such as a M-Audio product.
This mic, I believe also runs on a battery, when phantom power is not available...so check the battery.
Or, simply, your record levels are set too low.
May 20, 2010 | Rode NTG-2 Professional Microphone
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35684.exe
Windows XP sound driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
My microphone won't work. I can't hear my voice.Toshiba Satellite
Check which microphone device u have set up. Try changing it around. Also try just speaking closer to the microphone and into the mic. Some mics just are not good.
Aug 04, 2009 | Toshiba Satellite P105-S6104 Notebook
Tascam DP02 - LOW VOLUMES!
Phantom power should only be used with a condenser/ribbon mic. If you're using a dynamic mic (like the one in the photo) you don't need phantom power. Also I run my mics and instruments through a mixer, then into the unit. Also if you're mixing your masters at a low volume, the CD will play at a lower volume. Try mastering at as high a volume as possible, avoid clipping of course. But get it as loud as possible while mastering. Then the master copy should be louder. I have a DP02 and found out it needs decent monitors to mix and master. That's all I've got.
Apr 15, 2009 | Tascam DP01 All-In-One Recording Package...
Telex M-560
may be mic preamp is not working correctely. condenser microphone voltage is very low or mic is fault . check your microphone cable . preamplifer of condenser mic may be leaking .check ur mic driver and audio .
Feb 22, 2008 | Telex M-560 Consumer Microphone
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Problem recording when connected to computer
In the volume control panel look for mic boost and tick the box to boost the microphone volume. It's under options properties/Advanced controls etc.
Apr 13, 2007 | Sony One-Point ECM-MS907 Consumer...
Pantech vega r3 IM a850l dual sim unlocked gsm phone Logo
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
