Question about RCA Car Dc Charger For Drc99371e 7" Portable Dvd Player
Rca drc99371e - audio but no picture disc works ok
Cms-c333 does not play discs
Hello
Check whether the inserted discs spins inside the unit. If it does spins and still not reads it and play automatically, the laser pickup unit of your RCA set is damaged, and should be replaced with same type and number. If it does't spins at all, the sled motor is faulty and should be replaced. For both repair work, you have to disassemble and reassemble the deck mechanism. You must have skill in this work. OK.
Jan 19, 2012 | RCA RS2521 Shelf System
I load the disc in my player, and I get audio, but I get no picture. What am I doing wrong?
Hello sir in which player are u trying to play it ??? Whats the video format ???
Mar 13, 2008 | Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Rca rtd155 dvd player continues to read no disc with a disc in it.
Try to play a CD audio. If it plays OK then the video laser is bad in the player. If it doesn't play, open the player and inspect the lens for dust and clean carefully with a "Q" tip with alcohol. If these remedies don't work, then replace the drive.
Nov 01, 2010 | RCA RTD155 System
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Baddisc
if the discs are in good order and play ok on other dvd players you may need a lens clean, even a dirty lens can still still audio disc
Sep 03, 2008 | RCA DRC8052N DVD Recorder
Disc player does not work
Try using a cleaning disc, run it for about 20 to 30 seconds. If that does not help you do not really have any other options, RCA does not sell parts for the audio equipment anymore. They stopped about a year ago or more. I work at a authorized RCA service center and we can not repair any of the RCA audio equipment because of this.
The problem with your CD player is most likely the laser pick up, when it goes bad it can not read the disc's so it thinks there is no disc in it. The laser pick up is the most common reason for your type of problem.
If it is under the RCA warranty still you can send it to them and get a free replacement, if not under warranty you may as well trash it and buy a new one from a different manufacturer. The RCA audio equipment is not very good quality. That is the reason they no longer offer parts for them, it is cheaper for them to give you a new one than to pay a service center to fix it.
Jul 12, 2008 | RCA RS2650 Shelf System
Disc will not play or record message disc empty disk full
did you try a dvd movie do they play if so buy a different brand of blank dvd this happened to me i use
dvdr= sony ok
retail plus ok wal-mart brand
imation ok
at&t nogood on the rca machine
dvdrw= dataware ok
imation ok
cdr =tdk ok
these are all the brands a know are working on rca machines!
but keep in mind you can buy the most expensive blanks and they may or may not work on different machines
Dec 04, 2007 | RCA DRC8052N DVD Recorder
RCA Car Dc Charger For Drc99371e 7" Portable Dvd Player Logo
15 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
