SOURCE: User Manual for 90800 Gaggia Coffee Maker
Check out this site they have a wide selection of manuals. http://www.espressotec.com/store/pc/Support-Manuals-c12.htm
SOURCE: There seems to be a lot of water in the dump box.
The amount of water will vary with the strength of coffee selected.
On the front control under the cup symbol is 3 beans,pressing these will increase strength .
All bean lights on strong.
All details should be in the manual or available online.
SOURCE: Gaggia Platinum Vogue Built in Grinder
Just use the whole bean. Using pre ground coffee through your grinder will screw the blades completely.
However if you have a decaff option that allows you to put coffee directly into the brewer that would be ok........just dont put it into your hopper that feeds the grinder.
SOURCE: I have a gaggia platinum vogue that wont brew
Some times The steam knob may be slightly open. Twist the steam wand knob towards you, firmly, to a fully closed position.Check Pressure releif valve, the fill water inlet is on.Block in solenoid valve.
if still persist the pressure gauge should be replaced.I had a case where the Espresso had pressure built in and it may blow out.So please call the service man for your safety.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: my gaggia classic steam control knob is inaccurate
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine.
During assembling valve change 2 o rings and put one fitting 1/4'' to block the shaft coming out.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
