Question about Locks & Locksmithing
Laurastar steamax g2 keeps beeping when water level is correct
Water level full but iron keeps beeping
faggly
  • 74 Answers
SOURCE: Steam iron just spits water
Hiya .. your problem is more than likely to be one of two things
1. The element is overheating, which means the thermostat is not functioning as it should.. can you hear the thermostat Clicking? if so
2. No matter how soft your water area is.. there is always scale build up around and within the jets, try a good propietary descaler..... White vinegar is a good alternative.
Fill the iron with equal parts vinegar to water, and letting it steam until dry, rinse the tank with clean water, refill it and shake the water through the steam holes over a piece of newspaper/material... Test an old cloth before ironing on anything expensive. It should sort your prob ..... never advisable do this on a new iron as the acidity may damage the iron!
Regards Faggly
Posted on Mar 24, 2008
  • 225 Answers
SOURCE: water full alarm
Hi, There should be a little actuating rod poking down from the roof of the bucket chamber which contacts the bucket-float at one end and a microswitch at the other. The microswitch
must be activated to make the compressor and fan run.
Check this if you can to see whether this rod or lever is present, absent, lying on the floor or just plain stuck. If it is stuck in the "full" position then you'll probably have found the problem.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to
help you further. Cheers, D
Posted on Jul 13, 2008
ginko
  • 19396 Answers
SOURCE: washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Posted on Feb 20, 2009
  • 4088 Answers
SOURCE: I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
Posted on Aug 01, 2009
heatman101
  • 43501 Answers
SOURCE: Rowenta model 1700W. Water leaks out front of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
How can i dismantle a laurastar s4 iron?
not really-- use the correct iron cleaner and if that doesn't work, the damage done dismantling the iron will require a new unit any way
May 11, 2016 | Irons
Tip
Cleaning a Steam Iron White Scale and Brown Water
If you are having problems with your steam iron spitting out brown water or white scale all over your clothing, then you need to read this tip.
Both of these problems are caused by poor quality water being used in your steam iron.
The problems are different in that they are caused by two different types of poor water quality. The brown coloring of the water is usually caused by organic matter or iron mineral in your tap water.
If you are getting white scale on your clothing from your iron then it is usually because of calcium or other minerals in your tap water.
Either of these problems can also contribute to spitting or leaking of the iron when in use.
To clean the inside of the iron you must first empty all the water from the iron. Then fill the iron half full with bottled spring water and then fill to full with vinegar. Run the iron at its hottest setting for 15 minutes and then drain the solution. Fill again with just the bottled spring water. Reheat and then empty. After removing all of the water, turn on the iron and let it sit in the horizontal position for a few seconds to evaporate the last of the water. This will not hurt your iron, but will remove all the moisture before storage.
To keep your iron working well, use bottled spring water, and remember to remove all water before storing your iron. Always allow the iron to cool and store it on its heel.
Using the right water will prolong the life of your iron. Commercial de-scaling cleaners are hard on the inside of the iron and can cause leaks. Do not use distilled water, as it is too pure and will not produce much if any steam.
on Jul 14, 2010 | Irons
I have had a laurastar iron bought from John Lewis on the. 16/01/10, it has just exploded on me, please let me know if I Can get in touch with someone to repair it ? I live in glasgow, thank you look
cannot look into your wallet ...but i would just get a new one or secondhand these things are so sensitive with their water connections once you take it apart you cannot get it together again without leaking...
Nov 11, 2014 | Irons
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 14, 2012 | Irons
Iron will not heat up
See the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 23, 2012 | Unknown LAURASTAR PREMIUM S3 Ironing...
I have a Bush IN632 steam iron which is not generating steam. Can anyone point me in the correct direction as to what the fault may be?
took mine apart found that the base unit had limescale build up to such a level that the whole water chamber was full of limescale. Need a special security screwdriver
Jan 30, 2011 | Oreck TS100 Iron
My new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Nov 13, 2009 | Irons
Aug 01, 2009 | Hamilton Beach Steam Excel 14770 Iron
My dehumidier keeps beeping
Check the filter and make sure that the water level is correct. If all is correct then replace the water level sensor
Feb 14, 2009 | DeLonghi DE400 Dehumidifier
Locks & Locksmithing Logo
46 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
