Question about HP LaserJet Pro 400 M401DN Laser Printer
It makes a grinding noise and leaves lines on paper
3 Suggested Answers
  • 217 Answers
SOURCE: when i print, the printer makes a grinding noise.
Remove the fuser unit and check if there is a residue on the side of the gears. If so, you 'll have to replace the swing gear assy. Partnumber 5851-2766. It is not an easy job!!!
Gerrit Jan
Posted on Nov 02, 2009
SOURCE: My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Posted on Jan 21, 2011
HP Officejet Pro 8500 Wireless All-In-One InkJet Printer Paper feed will not drop down every time, and is making a grinding noise. Is replacing that piece available?
Hi. You leave a question mark?
I don't understsand what you mean by Papaer feed will not "DROP DOWN"?
I to have the same printer, the paper feeds from the tray (s) from below.
A little more info please?
The grinding in the system trying to feed through the paper.
Just a thought, turn the printer round find the release levers and check the internals for paper jam.
Mar 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
Canon mf6530 crumples paper and makes grinding noise when trying to print.
I pressume that paper is wrinkled in fixing section. Probably the fixing bushings are worn out. The grinding noise could be from paper when it stuckes, but also from gears.Call service.
There is a trick if paper is moisturized. Flip paper in cass. up side down, and try again.
Jun 14, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Loud grinding noise and doesn't take paper.
sounds like the shaft has slipped off the bearing end support.
disassemble and make sure end plates/bearings and shafts are in proper position, and try again
Mar 31, 2010 | Office Depot Ativa DQ60M Shredder
HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Oct 09, 2009 | HP LaserJet 1320 Printer
I was shredding paper when it started making a loud grinding noise and wouldn't accept any more paper. I've tried running it back and forth, but it only goes, maybe half way, either way, and it still...
This is a very common problem. Go out to the hardware store and buy some silicone spray. With the shredder unplugged, spray a good amount of the silicone inside all of the teeth and try to get all sides.
Plug it back in and work it back and forth a few times. It should work better with less noise now.
Jul 24, 2009 | Fellowes DM15C Shredder
Feb 26, 2009 | HP Office Equipment & Supplies
Grinding noise when printing and cuts paper
There may be something stuck in the area of the perforation, like a paper clip, paper debris or some foreign material. I would look in that area with a flashlight and see if there is something in the Paper feed roller area.Something may have come loose if you had a paper jam. Let me know.
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP LaserJet Pro 400 M401DN Laser Printer Logo
Seeker5211
Seeker5211
