Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
State select pr650povet hot water heater controller, roberts haw continulisly flashing water htr wont turn on till reset or ignitor cleaned but then only works for short time
WonderTech
  • 268 Answers
SOURCE: water heater not firing up
Make sure thermostat is turned to 120 to 150 degrees Fahrenheit. Turn the thermostat down and back up to see if it ignites. If it lights put the cover back on and set it to temp you want it to be. if not, you have a bad thermostat.
Hope this helps.
Posted on Aug 14, 2009
mrhotandcold
  • 248 Answers
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Posted on Oct 31, 2009
SOURCE: The control unit needs to be reset when I loose power
have two boilers one a rheem the other raypak, the raypak keeps turing off i have to push the reset button. what could be wrong
Posted on Jan 30, 2010
  • 77 Answers
SOURCE: rheem model #GP40T6PF00 lp hot water heater Will
sounds like one of the saftey relays might be going bad. or the ingniter might be cracked or need cleaning
Posted on Mar 08, 2010
  • 2841 Answers
SOURCE: I need to remove and replace the ignitor on my
http://globalimageserver.com/fetchDocument.aspx?id=7deedb00-1e6f-4d35-89c2-9060ed32f00a
Pay close attention to pages 16 through 30. The red button on the display board when pressed will reset the control.
Posted on Oct 28, 2010
Water heater pilot light is out, cant restart intelli vent controller
Possibly the air intake located at bottom of heater needs to be cleaned with feather duster under water heater.
Read your product manual for steps.
Copy following link for general illustration.
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
http://waterheatertimer.org/pdf/Flame-Arrestor-Screen-Cleaning.pdf
Other causes can be bad intellivent gas control valve, poor venting, hot attic, low gas pressure, dirty combustion parts, tripped FV system.
Copy following link for available intellivent troubleshoot resources:
The service manuals are large files and open slowly.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Jul 26, 2012 | Water Heaters
Thermos stat
thermostat?
what are you trying to do, replace, reset?
most hardware stores have these, but I would replace both unpper and lower, not just the one.
make sure you set both to the same temp, the heater will work better.
just follow the instructions in the package. make sure you turn off the power before you start.
Aug 07, 2010 | Reliance WATER HTR/STATE...
Rheem model #GP40T6PF00 lp hot water heater Will
Mar 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Rinnai tankless gas water heater and this things beeping and flashing 12 everytime we turn on the hot water the water will get hot but you have to wait for it to stop beeping
Error 12 is failed ignition - this can be caused by many things, but normally a low gas pressure, or no gas pressure upon ignition.
Try turning the hot tap on very slowly till till the control shows burner is lit. Then turn it on faster. If it stays going with no error, you might have a faulty regulator, not opening fast enough to meet demand. Especially common with lpg models,a lot rarer on natural gas.
Oct 27, 2009 | Rinnai Water Heaters
Hot water heater states lockout
lucky for you I jst did one of these the other day same problem,, check the wires on the ignitor, some of them are thinly coated and causes them to short out, wrap electrci tape around them individuly turn off the unit , wait 30 sec, turn it back on at it;s lowest tem hold both temp buttons at the same time till lights come on the after it lights set the temp
Jun 06, 2009 | RTO W4 A.O Smith Gas Hot Water Heater...
Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.  1 fan comes on. 2 switch is made from the airflow of the fan.  3 ignitor come on 4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again.  Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube. Good luck.
Mar 16, 2009 | Water Heaters
Rinnai *85e remote hooked up no hot water and no reading on remot
did you turn the unit off before hooking it up ? Any function on a tankless rennai the pwer has to be turned off and the priority button has to be pushed in,, if you have the manuel it tells you haw to do this,,
Feb 24, 2009 | Rinnai Digital Remote Water Heater Control...
No hot water out of a rtg-74pvp-1 tankless water heater
in order to reset the unit you will have to turn the temp all the way down then unplug the unit for 5 min,, remember it is a computer and it knows, after plugging in back in after the five min, reset the temp open up a fauset while doing this, that way it will be regestering the flow of water to set the temp by
Dec 18, 2008 | Rheem Tankless Hot Water Heater...
Rheem water heater with powerglow ignition wont re-light
I have fixed mine. The problem part is the Ignition Control module. It is made by Robert Shaw part # SP10758. I paid $93 plus shipping.
Works great now. A repairman wanted to sell me a gas valve for $488.
Watch out for these people.....
Nov 06, 2008 | Water Heaters
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
150 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
