Question about Samsung Washing Machines
Samsung wa400pjhdwr/aa te error code
Te error
  • 4 Answers
SOURCE: LG washer tE error code
A "tE" error code is more than likely the "thermistor". Supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error...cleaned and replaced...no problems since! No screws needed to be removed. My thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center. I removed the entire grommet. It easily pops back into place.
Posted on Jun 02, 2009
SOURCE: LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Posted on Oct 29, 2007
MNTECH
  • 1543 Answers
SOURCE: error code tE
tE is a thermister error. (temperture sensor) Located at the water heater element.
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: tE error code on my
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Error code tE
if you replaced the thermister
and tE comes up
then its the heating element has failed
and or its thermal safety fuse set up perhaps failed also
Apr 28, 2015 | Washing Machines
Samsung NE595N0PBSR range is giving error code "tE"
te error code is (touchpad error). you have to replace the touchpad assy. the board and overlay.
Apr 06, 2013 | Samsung NE595N0PBSR 30" Electric Induction...
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
Washing machine error code is tE, something to do with the power?
tE stands for Thermistor Error. This is a problem having to to with the water temperature, possible causes are: water heater was low on hot water, or the thermistor gave a faulty reading. It can be corrected by unplugging the machine for 10 minutes and restarting the machine.
If this helps you please rate my solution.
Thanks, Repairman45
Dec 02, 2010 | Samsung Washing Machines
Samsung washing machine error code te?
The problem could be the thermistor, but before you replace it, check the wiring. Many people with this error code have found one or more broken wires. If you call for service, be sure the technician checks the wires.
Jul 01, 2009 | Samsung Washing Machines
TE error code on my LG WM2688 washer. Thought I started cycle, went downstairs. Checked back and noticed it never started and had a tE error code on screen. Manual says, unplug and call for service. ...
Apr 29, 2009 | Washing Machines
Washing Machines Logo
211 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
