Question about SimpleTech 1TB SimpleDrive USB 2.0/eSATA External Hard Drive
What is DC Voltage - with SimpleTech 1TB SimpleDrive USB 2.0/eSATA External Hard Drive
With SimpleTech 1TB SimpleDrive USB 2.0/eSATA External Hard Drive
TomSolomon
  • 50 Answers
SOURCE: SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
Posted on Jun 21, 2009
  • 126 Answers
SOURCE: General questions regarding simpletech simpledrive.
You probably have to initialize and/or format the drive.
Right click my computer and click Manage (assuming windows xp)
Go to disk management
See if you see the drive listed somewhere there. Should show approximately 950gb disk drive
If so right click that drive listed and choose either format, or create partition.
If you create the parttiion, make sure to click quick format, otherwise it will take a long time.
Hope this helps
Posted on Jul 09, 2009
  • 1584 Answers
SOURCE: SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Posted on Dec 23, 2009
nonontech
  • 4737 Answers
SOURCE: need to know dc voltage for simpletech external
12 volts Dc and 1.5 ampere with External terminal as Negative Polarity and internal as Positive Polarity.
Good luck
Thanks for using FixYa.
Posted on Jul 06, 2010
  • 79 Answers
SOURCE: My SimpleTech SimpleDrive Pininfarina 500GB
You may have a power supply that is defective or is failing. Try another power supply, 12V, 2A, center pin positive.
Posted on Jan 24, 2011
What is the DC Voltage
If it has 3.5" Hard disk inside DC voltage is 12V.
If a 2.5" Hard disk inside the DC voltage is 5V and can be powered by USB alone.
Nov 21, 2013 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
Where can i purchase a power cable for my SimpleTech Pro Drive 1TB External?
You can use any 12V/2A tip positive power supply at Radio Shack, Best Buy, etc
Aug 01, 2011 | SimpleTech 1TB SimpleDrive Pro External...
Got simpletech duo pro enclosure. Put 2 X 500 GB SATA drives. XP tries to initialize 8GB drive and fails. need drivers?
disconnect the
usb cable from the drive and hold in the reset button on thr drive wth a oaoer clip for 4 seconds while the drive is running, rebout your system whith the running and you should be able to format through manage drives
Oct 03, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
I have a simpletech 1TB ext. hard drive BOM No.
You need to install the hard drive driver for the PC to recognize it. If you don't have one, just look in the internet for a free driver.
Regards,
Jeep Brainy
Aug 14, 2009 | SimpleTech 1TB SimpleDrive Pro External...
External Drive is making noises and computer wont recognize
Just to be sure try the drive on another computer. If still the drive is not detected you may have a problem with the drive's head.
Aug 04, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Hope this helps
Jul 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
Hi Would you tell me how long 1tb IOMEGA hard drive formating will take?
It depends on how it is connected to the computer. A drive connected through an eSATA port should be able to format 1TB in just 1 - 2 hours depending on how loaded the system is (background processes/services, other use while it is formatting, etc). If it is connected via USB2.0, you are looking at approximately 6.3 times longer or up to 13 hours.
If you could reach and constantly maintain the theoretical maximum throughput on eSATA, it would only take about 45 minutes.
May 30, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
SimpleTech 1TB SimpleDrive USB 2.0/eSATA External Hard Drive Logo
29 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
