Question about Tascam DA-30MKII
Tascam da30 dat ne veut pas loader le tape load and eject the tape
Quand je met la casette dat et que je ferme la porte elle ejecte la casette ne veut pas la loader
mrwtech
  • 59 Answers
SOURCE: tascam da30
www.datrecorders.co.uk/da30.pmp has a pdf version you can download for a fee.
Posted on Sep 10, 2008
petraman7
  • 1175 Answers
SOURCE: Tascam DA30 Mk1 drawer and noise problems
HI...
There are 2 belts in the mechanism that would need replacing.
I've fixed 2 of these.
There's a very small belt on the underside of the tape drive assembly
1.55 inch belt x 0.039
www.studiosoundelectronics.com # SBO1.55
Dont remember the other
Posted on Apr 10, 2009
satavlad
  • 405 Answers
SOURCE: I have a Tascam DA-30 which ejects the tape
Many different things could sause a problem, belts, mode switch, capacitors in capstan or head motor drive circuit. Hard to say what exactly is wrong with the machine without looking at it.
Posted on Dec 04, 2009
caroldon
  • 17129 Answers
SOURCE: TASCAM DA-30 tape transport error
When you use any cleaner or lubricant it must be only for the moving part and must never stray into the transport section. Also what is required if there is any frictio is to dry wipe and set. Now when you lubricant got sprread into the head, the oil will act as a great adhesive at higher speed and got the tape entagled. So please wipe dry all the oil of the headd and do nto damage the head with the wipe touching the delicate ferrite heads in the slot, DO NOT TOUCH THIS SECTION but with an even paper with soft brushes. Now check you reel drive and see if there is dirrt lodged in clean and reset., put the set on for regaining lost values as many electronics capacitors may have lost value by drying. If the tape up does not move it is a mechanical problem and you must check for the drive and the friction wheel. If however the reel works and the count does not happen and you get the error , then your reel sensor is faulty. Check these points and confirm, Hope this advice helps, Good day.
Posted on Jul 26, 2010
floydfr1
SOURCE: tascam 2488 mk2 [auto repair program]
alors c'est quoi la solution car moi pareil !!!
Posted on Sep 15, 2012
Je n'arrive plus a faire suivre mes mails et videos diaporamas une fenetre s'ouvre avec un panneau interdiction me disant que le mail ne pouvait pas etre envoye . que faire ? d'avance merci .
Bonjour, il va falloir que tu fermes ton compte Yahoo et que tu t'ouvres un compte avec gmail ou hotmail. Ce qui arrive c'est que Yahoo intercepte toutes les correspondances et ne les envoient jamais a nos comptes. J'ai deja eu le meme probleme et ma compagnie d'internet ont decouvert que Yahoo prenaient tout ce que j'envoyais (meme quand j'envoyais des photos, videos ou couriels a mes comptes gmail et hotmail). Depuis que j'ai abandonner Yahoo, je n'ai plus de probleme. :-) J'espere que ma reponse t'aideras.
Nov 21, 2011 | Yahoo Mail
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
La porte du compartiment batteries ne reste pas fermée, les ergots de verrouillage sont cassés. Ou je peux me procurer la pièce de rechange...
Votre porte de batterie ne restera pas ferm?e ? J'ai le m?me
appareil de photo et m?me probem. Je l'ai pris dans un pourvoyeur de
service et ils ont pris une forte bande et l'ont enregistr? ferm?.
Ils ont dit que la r?paration ?tait tr?s co?teuse. J'ai utilis?
l'appareil de photo cette voie pendant les ann?es. Je sais qu'il a
l'air de pauvres fixent. Je ne peux pas constater qu'un endroit
ordonne des parties. Vous pouvez contacter la compagnie au fond de
cette page :
http: // www.fujifilm.com/support/
J'esp?re que cela vous aide. Merci d'utiliser FixYa. Estimez s'il
vous pla?t cette r?ponse.
Dec 26, 2010 | Fuji FinePix S5000 Digital Camera
Je n'ai plus de tonalité quand je téléphone, plus de son
Mouais, il manque un peu d'info pour vraiment cibler le probleme mais je vais commencer par y aller avec le plus simple et évident, et si ce n'est pas le problème, récris un commentaire pour préciser pas de son dans quel sens. Donc, tout simplement a priori comme ca, je dirais que le haut-parleur de ton tréo est brisé, ou encore qu'un des connections ou soudures qui le relient a la carte principale du tréo a cédé. Si tu es sur que ce n'est pas ton cas, alors faudrait que tu précises si t'as juste aucune sonnerie mas que tu entends quand meme quelques sons quand par exemple tu fais jouer un MP3 ou quelquechose. Ou encore si vraiment tu n'entends pas parler la personne quand elle décroche mais que tu entends ta sonnerie quand quelqu'un t'appelle. Bref, essaye d'etre le plus précis possible et de me dire tous les modes ou le son fonctionne ou fonctionne pas. Voila, donc en espérant t'avoir un peu aider, sinon j'attends de tes nouvelles pour pouvoir essayer de mieux comprendre le probleme et te trouver une solution.
Jul 28, 2009 | Palm Treo 750v Smartphone
Broder avec la singer tradition 2250
AUGMENTEZ(LEVEZ) TOUJOURS le pied de presse quand le filetage le fil sup?rieur.
Apr 25, 2017 | Singer 2250 Tradition
Mon appareil canon ne marche plus!
Salut
Desole, mais mon francais est tres mal... Votre objectif a été endommagé dans la baisse et doit être réparé ou remplacé.
J'espere que ceci aide.
Thomas
Sep 19, 2008 | Canon PowerShot A550 Digital Camera
INVERTER
le probleme est resolu voici l'explication : une fois que la tension des batteries est dans la tolerance ça demarre est ça prend la charge le + normalement une fois que la tension des batteries est hors tolerance ça declenche dans mon cas les batteries etaient à plat car le chargeur ne fonctionne pas bien j'ai bien charger les batteries puis reparer le chargeur et tout est entrée dans l'ordre
Sep 13, 2008 | Electronics - Others
Je ne suis plus capable de prendre de photo avec ma cam?©ra ???
N'inquite pas. C'est parce-que tu essais de prendre un foto par utiliser le petite button sur la camera. Cela n'est pas correcte. Tu besoin de cliquer sur l'icon pour la camera sur la desktop de votre ordinateur. Quand le fenetre pour Microsoft Lifecam a ouvre, il y ont tres buttons, cliquer sur l'un qui resemble une camera. Voila, ce come ca que tu peut prendre un foto. Bon chance (et pardone-moi pour le francais qui e suelement come ci come ca.)
Jul 24, 2008 | Microsoft LifeCam VX-3000 Web Camera
Electronics - Others Logo
41 people viewed this question
Top Tascam Electronics - Others Experts
Lyle Siemens
Lyle Siemens
Computer Links
rjivaro
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
