Question about Panasonic Dryers
Where can I find grille clips for an fv lp003 fan?
Fan grilles
SOURCE: Lakewood 200I Floor / Box Fan
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
Posted on Jun 03, 2007
SOURCE: Removable grilles for easy cleaning?
We just figured this out ourselves. There are four (4) screws on the back of each fan that when undone it releases the grill for cleaning. But the fun part is getting the screws back in to the little holes. But all in all we got it clean...
Posted on Aug 21, 2008
SOURCE: remove grille on fan fan
I have taken mine outside before and used a leaf blower. Blows all of the dust out and works great on the areas that cant be reached
Posted on Jan 04, 2009
SOURCE: need to remove gril to clean blade and grill
You can remove it by pressing the clips. I used a flat screwdriver as there was no way my thumb would fit in there. But it worked like a champ with the screwdriver. I pressed two clips and it popped and then I could simply lift the grill away from the fan blades.
Posted on May 06, 2009
  • 272 Answers
SOURCE: Trying to remove service grill for Nutone QT140L combo fan/light
Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
Posted on Jun 02, 2009
How do I remove the grill to get to the fan blades to clean them?
There's usually a screw or a clip which locks the two halves of the grill together. You need to remove the screw or undo the clip. Then you should find that one half of the grill cage just lifts out of its locating lugs. Once you've got the cage open you have access to the fan impellor. This should be removable. Sometimes by undoing the locking screw or just by pulling it off. You can now get to all parts of the fan assembly to clean it. Here are some links to useful sites:
DIY Home Improvement Information DoItYourself com
YouTube
Breaking News and Opinion on The Huffington Post
Jul 25, 2015 | Dryers
How to replace cooling fan on peugeot 206
The cooling fan on the peugeot 206 is situated between the front grille and ththe radiator, To gail access to the fan you first need to remove the 4 push/pin fixings that hold the upper grille panel ,then remove the 2 torx screws from either end of the upper panel (one at each end. Next the lower grille panel needs to be removed by disengaging each end from just below the headlights, these ends are held in place by clips ,and care must be taken when pulling the lower grill from these clips.Once you have both upper and liwer grille removed ,it a simple matter of unplugging the fan connector ,and removing the 3 fixing bolts , the fan can then be removed ,
Apr 02, 2012 | Cars & Trucks
I HAVE A Vornado Type 630 fan. How does one remove the cover so that the fan blades and circular grill can be cleaned. Tahnk you, Joanna
There are three clips the hold the grill to the cowl.
One clip at 11 o'clock, one at 2 o'clock and one at 6 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shold come off.
I can send pic if needed.
cawicks at g mail . com
Feb 14, 2011 | Vornado Circulating Fan
How do I clean mynvornado fan blades
Look along the outer edge, on the back.
Use mild soap and water the clean the blades after removal.
Dec 18, 2010 | Vornado Circulating Fan
How do I open to clean 600 series vornado floor fan
Look along the back, outer edge of the fan.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill should come off. The blade just pulls off. It only goes on one way (due the the "D" shaped shaft).
Oct 18, 2010 | Vornado Circulating Fan
Screw to leg has fallen off how do I get cage off of fan?
I have not been able to find a large picture of this fan, but I will tell you what I have run into in the past. On some of the fans there are small clips around the grill where the front and back pieces come together. It would be a case of opening these clips and sliding either the front of back grill off. Reverse the process when putting it back together. On others I have found small plastic wire ties holding the two grills together, one at the screw locations where the legs hook onto the fan. These need to be cut with scissors or wire cutters and replaced with new ones when putting the fan back together. New wire ties can be purchased at Home Depot or Radio Shack.
Please let me know how you make out and I will keep looking into this.
Paul
Sep 19, 2010 | Patton U2-1487 Floor / Box Fan
I cannot get the spring clips to work in the slots that the diagram shows, therefore I cannot get the grill in place
I have the same fan. Not easy to do, but squeeze the two spring ends together and slip in proper hole, one on each side of fan. Once this is done, push cover straight up and into position. The springs separate once the grill is raised and in doing so, they hold the grill in place. A bit difficult to pull the grill back down to replace bulbs, but holding grill close by the springs will help.
Sep 15, 2010 | Broan-NuTone (8663RP) Ceiling Fan
How to remove the grill to clean the Vornado fan?
You cannot with the clips... its impossible.. wound up breaking the clips... and STILL cannot get grill off. Don't ever by a Vornado if you cannot clean it!
May 10, 2010 | Vornado Circulating Fan
Our new bathroom fan is not clearing the room the ceiling is wet and the paint peeling the fan is model #FV-LP003
I use to be a chimney sweep. One of my jobs was to clean vents for dryers and bath vents. What could be your problem is that you have a bird nest in the vent system. It sounds to me that you have a vent on the roof for the fan. A bird could have damaged the cap to gain entrance and built a nest. With the cap gone, rain can come in. With the nest, it will not vent out the room. You could call your local chimney sweep company and they will clean it for you. Or if you are capable, Lowe's or Home Depot sell dryer vent cleaning rods. They are sturdy but flexible rods with a 4" brush on the end. Two other handy tools will be a high power shop vac to **** out anything from inside the vent, and a high power blower that has vacuum capability to use out side the house. Cafe full though, if it pulls out a nest, it will shoot it out with great force.
Jan 23, 2010 | Panasonic WhisperFit-Lite Low Profile...
Need to remove gril to clean blade and grill
Apr 24, 2009 | Vornado Circulating Fan
Dryers Logo
26 people viewed this question
Top Panasonic Dryers Experts
Electro Med Services...
David Emmel
David Emmel
michael vanier
Are you a Panasonic Dryer Expert? Answer questions, earn points and help others
