Question about SWR 750X Pro Series Bass Amplifier Head (750 Watts)
Swr 750x has low volume at a high number on dial
I can have it on 4 and it very low.
Rms b80 bass guitar amp has little volume in the low side jack , hi side jack is fine just not as much bass
The low in side jack has a lower vol. but should only be1/4 less than the high in jack on most amps, --try this,-- plug guitar in high in then take all the treble off and 1/2 mid. range bring up bass range and if you have equauzation bring down 26k 5k 10k about 2 notches or points. See if that give you better bass tone.
Oct 10, 2013 | Bass New Rms 40 Watt Bass Guitar Amplifier
Swr 750x has a short
The 12ax7 preamp tubes will act just like that when they get old, in fact, this would be my 1st check before I go any further, other than ventilation and heat .Make sure you are using the right impedence output jack to match your cabinet. Make sure the effects mix level is not overriding your guitar signal. Also, make sure that your signal is not being clipped showing the red led's. Also, the variable limiter control, if turned up very high, will do that to a point similar to a compressor/limiter. I would definitely check the tubes for the crackling sound could be just that.
Mar 11, 2013 | SWR 750X Pro Series Bass Amplifier Head...
Humming kind a loud it bothers a lot so anoing.
Unplug the inputs to the amp. If hum disappears, then you need to fix the guitar or the cable or keep the guitar from magnetic fields which are present near amps and other powered equipment. Use of Humbucker pickups helps a lot. If amp has objectionable hum with inouts unplugged, take it in for repair.
May 09, 2011 | SWR 750X Pro Series Bass Amplifier Head...
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender ultra deluxe amp volume max out a number 7 volume control. will not get any louder
It is likely that the amp is flat topped at the 7 setting. When the amp is producing the maximum voltage output it is capable of, that is ALL you can get out of it... The numbers on the dial mean NOTHING and are only relative. If you have high output guitars you might find the maximum might only be 3 on the dial for example...
If you need it louder, get a bigger amp and speakers. You should ALSO get a sound meter and follow OSHA guidelines for sound exposure... I know several musicians that now are nearly deaf because of being exposed to high sound levels... their music careers are now gone as they can no longer hear well enough. You need to protect your hearing for the long term. Great musicians don't need loud, but quality and inovation in their music.
Jan 07, 2011 | Music
THE U &L SOLO PANEL PLAYS VERY LOW NO VOLUME YOU CAN HEAR IT VERY LOW WHEN VOLUME IS SET AT HIGH AND SWELL IS AT HIGH ALL WORKS JUST NO VOLUME
Who would have any idea of what make or model device you have? Sounds like some brand of organ. We are not mind readers on this forum.
Oct 14, 2010 | Music
I just got this bass and am getting speaker pop at low frequencies, any ideas of what is causing this? All other frequencies sound great.
If you are driving the speaker too hard it will pop. This caused when the voice coil is driven mostly beyond the pole pieces of the magnet. Without the magnetic field the back EMF of the voice coil drops off and the current shoots up. The voice coil can't move farther so there is a discontinuity of movement which causes a pop.
200 watts is a lot to put into a 12 inch speaker so you have to be careful to not drive low frequencies at excessive volume. It is both very hard on the amp and doesn't do the speaker any good either.
If you want loud lows, you should get a subwoofer of at least 15 inch speaker to handle the lows.
Aug 04, 2010 | SWR Workingpro 12 200watt 1x12" Bass Combo...
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Problem with volume dials in an electric guitar.
If you can't clean the pots or if you just want to try replacing them, try using
500k pots again, in case one or both of the pots is worn or dirty or
defective. If that doesn't work, and cleaning or replacing the
switches doesn't work, then the problem is probably elsewhere.
You could put a 500k resistor (with a sufficiently-high power rating of at least half the power rating (Watts) of the pot) in parallel with the pot, or, to cover all bases, put a 500k resistor from each of the two outer lugs of the pot to the middle lug. That should change it into the equivalent of a 250k pot. You could even just temporarily clip the resistors on, with alligator-clip leads, if you're very careful, just to test it.
Good luck,
The dude.
Aug 07, 2008 | Dean Dimeblade Tribute Electric Guitar
SWR 750X Pro Series Bass Amplifier Head (750 Watts) Logo
Top SWR Music Experts
Vito Vacirca Jr.
Are you a SWR Music Expert? Answer questions, earn points and help others
