Question about 831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS
Avital increase crank time - 831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
Nov 28, 2015 | 4103LX Remote Start System with Two...
, starts and stops my car 3 times in cold weather.
Hate to this but take it in to a shop that can service this unit. The reason i say that is because these and most command starts have systems that tie into the main brain on the car. If the problem is not in the command start it is most likely going to be on the car, one of the sensors is not reading right in the cold weather and this sends a fault code to cars computer which is read by the command start and the system shuts down. After 3 times in the cold the sensor warms enough to NOT send a code to the cars cpu and no fault code is sent so the command start assumes everything is ok and keeps the car running. Will say that since i have never heard of this system i could be dead wrong all the way, but would suggest you start with that. Hope this helps
Mar 18, 2014 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Avital 5303 kills engine while driving 1998 honda civic
you check to see if the engine was hot or something like if the water level in the radiator was down the sensors in the security system would pick it up
Jan 27, 2014 | 5303L 2Way LCD Remote Start Security...
1998 chevrolet k1500 series cranks but wont start
Contact AVITAL company. This sounds like the alarm is killing the ignition or fuelpump circuit. Sometimes there is a sequence used in alarm resets and you should know it if you are out in the Boonies without a Cell signal.
Feb 12, 2012 | Chevrolet 1500 Cars & Trucks
How do i reset my remote start car alarm avital 5303
i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
Feb 21, 2011 | 5303L Security/Remote Start System
Cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
Jan 28, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS Logo
85 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
