Question about OPIP Ipega Alcohol Tester Analyzer Breathalyzer for iTouch5/iPhone5/iPad4
No reading when blowing - OPIP Ipega Alcohol Tester Analyzer Breathalyzer for iTouch5/iPhone5/iPad4
How to replace valve cover seal
remover cover , install seal , put back cover
if you need blow by blow, read the FSM (factory service manual)
or alldata.com
login and read. how.
if keeping car , and doing DIY why not have the book?
why have to beg for data every inch of the way.
Dec 14, 2014 | 2006 Toyota Corolla
Efi fuse blows when car strts wher is the efi located
NO YEAR stated (old post)
there is no EFI fuse. sorry,
the ECU has 3 fuses.
FI, Dome, and IG-coil
all 3 run the ECU.
i do know what you ment.
but knowing the correct name makes reading the FSM better.
my guess 2 is you lost the fuse box cover and cant read the names.
guessing year at 91 -95
http://www.fixkick.com/power-elect/fusepanel-left-knee1w.jpg
the ECU fuse blows page. is here
http://www.fixkick.com/power-elect/blows-fuse.html
top reasons.
ECU bad CAPS
shorting fuel pump (they pull 4amps normal) if 10amps or
more they blow the fuse and or causes the ECU to click relays
like mad.
Dec 22, 2013 | Geo Tracker Cars & Trucks
The dryer doesn't blow any heat 11074972300
Check heating element with Ohm meter should read something.
Infinite reading means the coil has burnt out. replace.
Nov 04, 2012 | Kenmore 95087 Gas Dryer
30 amp fuse keeps blowing i was able to change it and it would start now it just blows at the turn of my key
If the 30 amp fuse blows there is fault or short within the igntion /fuel pump circuit. You need to check this case by ISOLATION. remove connection of the suspected sections one by one and confirm when the fuse blows as the particular circuit is connected.
Dec 23, 2011 | 2006 Pontiac G6
My x-box 360 is taking a really long time to read any games. in some cases won read at all. i think there is a dust problem. is this somthing i can do myself?
You could get a can of compressed air, and try blowing any dust that may be present off of the Eye.
However if you open the Xbox you will terminate ANY warranty that may be in place.
I would try to open the disk drawer, and blowing air into that, however that might not be the issue.
If you do have a warranty in place, i would try blowing it with the compressed air, and if that doesnt help just giving tech support a call.
hope that helps.
But whatever you do, do not make any contact with the reading eye.
that would end it.
Nov 16, 2009 | Computers & Internet
My wii doesnt read the games
Try opening the wii and taking ear cleaner swobb and dipping it in alcohole and wipe the laser very softly and smoothly. the laser is very sensitive and breakes easaly. then blow it with profeesional blower or blow it dry. then insert disk it should read. sometimes dust or even paper can be blocking laser read.
Aug 06, 2009 | Nintendo Wii Console
Zuma blows headlight bulbs.
They have a fairly basic electrical system, sometimes a bad battery can cause headlight bulb to blow.
loose connections can blow bulbs.
a blown bulb wont flatten the battery.
If the battery is good put a multi meter across + and- should read 12v or more, start the bike and shouldnt read more than13-14v, but has to be higher than the initial reading. 15v -20v replace the regulator
Apr 08, 2009 | 2008 Yamaha Crux
Volvo nav system "cant read disk"
Try using a can of compressed air to blow dust out of the unit. Insert the tub into the area where the disk is normally inserted. Blow the compressed air and remove dust which may be covering the lens which reads the CD. Also, try a different "Music" CD, be sure it is not an MP3 CD.
Oct 04, 2008 | 2004 Volvo XC70
OPIP Ipega Alcohol Tester Analyzer Breathalyzer for iTouch5/iPhone5/iPad4 Logo
620 people viewed this question
Top OPIP Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an OPIP Health and Beauty Expert? Answer questions, earn points and help others
