Question about GE Spacemaker 1.5 Cu. Ft. Over-the-Range Microwave - CleanSteel
How to replace keypad on GE hvm1540LN1cs - GE Spacemaker 1.5 Cu. Ft. Over-the-Range Microwave - CleanSteel
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
Ge microwave oven key pad short circuited JVM 1540
see the next steps. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 03, 2012 | GE JVM1850 1000 Watts Microwave Oven
Keypad 3 & 9 do not work on ge jes1290
The keypad control board must be replaced, cost can rival some microwaves.
Apr 17, 2012 | GE JES1290 Convection/Microwave Oven
My GE microwave is beeping and the display says F3
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
We would need your model number to give you more specific info, part ordering info, and en estimate if needed.
Simply contact me here with your model number and symptoms for free help.
On some models, the membrane keypad is peeled off and a new one stuck on.
In other models, the plastic frame must be replaced, and it comes with a keypad already installed.
May 12, 2011 | General Electric Microwave Oven
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
GE Spacemaker 1.5 Cu. Ft. Over-the-Range Microwave - CleanSteel Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
