Question about LG 55LD520 55 in. HD Ready LCD TV
Reset power supply on lg tv - LG 55LD520 55 in. HD Ready LCD TV
LG TV Button will not turn on tv, Remotes won't either. Have checked power supply and it's ok.
Have you unplugged the tv then plugged it back in--this will usually turn the tv on----have you had a power failure---brown out---power disruption of some sorts---if so unplug the tv for 24 to 48 hrs---this gives the tv a chance to reset---ck with your manual for situations of power problems as it may have instructions for this---all of this is based on that the batteries are good in remote.
May 31, 2017 | LG Televison & Video
TV powers on and and there is a backlight but no picture. The power supply board has been replaced but I haver no LG power up and drop down menus... Bad Control Board? My house was hit by lighteni
Hi, checking user manual there's no soft reset option so maybe the main board is faulty too, usually when there's a damage by lighting in power supply this also reaches the main board since they aren't electrically isolated.
Jul 08, 2015 | LG Televison & Video
Where is the reset button?
The internal power supply that is inside the TV is defective.
Apr 27, 2015 | LG 60LN5600 60" 1080p LED-LCD TV - 16:9 -...
60 inch LG Plasma, did have to push the power button 5 to 7 times to get the TV to power up. Now it will not come on at all
The tv before,the tv power supply board already have problems and was slowly dying,that why it require u to pushes 5 to 7 times for the tv power supply board to be able to sustance and hold power for the tv.Now the tv power supply board it is alot weaker or already dead.That why the tv dose not power on anymore.The tv power supply board that the board where the tv power a/c cord plug into it.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | LG 60PC1D 60 in. Plasma Television
I lost power in my house. I cannot get the TV to power up. Is there a reset button? what do I have to do to get power on the TV? All the other components linked to the TV are working.
Now,there is no power to the tv at all?Yes.Tries tv unplug,replug it back like about and hour later.That the resetting tv back to the factory setting.The tv now should be working again.If tv still have the same result,tv power supply board have problems,that the board,where the power a/c cord plug into it.Check the tv power supply board fuse,because u lost main power to the house.If u lucky,the tv power supply board only have a dead fuse,fuse is near where the power a/c plug,plug into tv to get it power.Fuse can buy it anywhere like Radio Shack like $1.50.After u repalced the fuse,if tv still getting the same result,than sorry ur whole power supply board have problems and it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 23, 2011 | Samsung LN52A850 52 in. LCD HDTV
The standby light on my LG 55LD650 is blinking red, and when i power it up the TV shuts off 5secs - 2min after it is turned on. I've disconnected the power to reset the TV and get the same result. Have...
i have that problem before..
iv open my tv.. i figure out that the capacitors of my tv are bloated.. (power supply portion)
and iv replaced them .. and it works.. like new..
Nov 05, 2010 | LG Televison & Video
I put on the tv but it it does not go on. Checked all wires and connections, and all ok.
Tries unplug the tv and the cable box,replug both it back like an hour later.The tv,now will reset itself,back to the factory setting.The tv cable box,will reset itself and upgraded it software.The tv now,should work again.Not,than the tv have problems,with it power supply board.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 03, 2010 | LG 42LC2D 42 in. LCD HDTV
My lg tv is flashing at the bottom and will not turn on
Unplug,replug the tv to reset it self?Not.Take the tv aparts.Power supply board have dead parts,call capacitors,check power supply board,that the board have a a/c power cord plug into it.That the power supply board.Know basic electronic's?Know how to do soldering,have tools like soldering iron and solders?Check power supply board for those dying capacitors parts,alway bulges up on it tops or puff up on it tops.These capacitors must be replaced in the power supply board.Now the tv shuold have stable ur power light and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 04, 2010 | LG RU-52SZ61D 52" TV
My lg tv wont turn on.
First, I would try leaving the TV unplugged for an hour so the TV can discharge and reset itself.
If this doesn't work, it maybe something simple like a blown fuses inside the TV that needs replacing.Radio Shack or some electronic store will carry the fuses.
If the other two ideas doesn't solve it, we're talking about a power supply board related problem. I can't actually look at your TV over the internet. But, the most common problem with flat panel TV are the power supply board for the screen itself and the main power supply board for the rest of the TV. Commonly a bad capacitor or transformer will be on the board.
If you have some electronic experience and want to repair it yourself, you can sometimes find a Service Manual for your TV over the internet. Normally, costs less than $20. It will have diagrams, schematics, and part number list for the TV.
Sep 09, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
LG 55LD520 55 in. HD Ready LCD TV Logo
41 people viewed this question
Computer Repairing
Computer Repairing
