Question about ETL Secure Logic 20710 Keypad Wall Vault
Wall safe keeps buzzing - ETL Secure Logic 20710 Keypad Wall Vault
Viking oven buzzes all the time when not in use
the low voltage transformer on the ERC control is vibrating from not doing anything,when you put a load on this transformer it will quit,only fix is to possibly remove ERC and jam a piece of NON-Flammable/NON-electrical metal to keep it from vibrating and try this first,if this doesn't help,replace the noisy board with this transformer on it
Jan 12, 2013 | Viking 27" Professional Select Built-in...
Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Nov 17, 2009 | Yamaha Music
I have a fat ps2 with a rumble controler problem
just keep ure ps2 safely and always shining . so always clean ur ps2 and make the best use of controllers carefully
Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
Audio buzz
Check to see if reversing the plug takes away the buzz. Some times turning the plug over in the wall socket i.e. reversing polarity, will remove the buzz.
Dec 09, 2008 | Philips HTS3400/37B System
Computer keeps crashing
it is the mother board you will have to goto emachines website and order new one i had same problem in a few days it will get worse
Nov 19, 2008 | E-Machines eMachines Desktop PC
Ac adaptor was dropped on ground, and makes a BUZZING SOUND. Is it safe to still use
It may not hurt anything; the transformer in the adapter has iron laminations which are normally potted with epoxy to keep them quiet as well as stabilising their magnetic characteristics. Dropping it has caused one or more laminations to come loose but it probably won't affect anything. You might feel the adapter now and then for a few days to ensure it is not running hot; warm is OK.
Sep 06, 2008 | Uniden 5.8GHz Dual Cordless Phone
We have a Samsung HDtv 1080i. While playing a video game yesterday just out of the blue the screen went blank and then all we could hear is a very light buzzing sound. The red light on the front of the...
The flashing light is giving you an error code as there has been some sort of failure in the TV. The buzzing sound could be the flyback transformer. Count the number of flashes. I'm sure the code will be for the flyback.
Jul 07, 2008 | Samsung Televison & Video
ETL Secure Logic 20710 Keypad Wall Vault Logo
141 people viewed this question
Top ETL Home Security Experts
Lawrence Oravetz
Are you an ETL Home Security Expert? Answer questions, earn points and help others
