Question about ASUS Computers & Internet
Error message 0xc000014c
Don't have cd drive to use for recovery
2 Suggested Answers
odiebugs
  • 949 Answers
SOURCE: Hard Drive Error during system recovery
You need to run a hard drive diagnostic disk in dos,(before windows starts) First check with HP, You can also use a program called HDD Regenerator 1.51. This will check the drive for bad sectors, and then you can try and repair them. This way you might
be able to see some of the data you want. If the sectors that where
repaired had the operating system on them, you should just get a new drive,(if not under warranty) then after you have a new OS installed on the new drive, you can plug in the old drive and see what you can recover.
Posted on Mar 20, 2009
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your windows installation disc and restart your computer. 2. Choose your language settings,...
Big trouble. Try safe mode, if possible. Don\'t use recovery procedure, just manually remove unnecessary things. Finally backup your data, and reinstall whole system?
Mar 19, 2014 | Acer Computers & Internet
I have an error message on my computer which appears everytime I sign in. What does it mean? STOP: 0x000000ED (0x86341B88,0x0000006,0x00000000,0x00000000) UNMOUNTABLE_BOOT_VOLUME
It ius fetal error.
It means your harddisk need fix bed indexing and tyoehr thing.
For that boot your computer with bootable recovery disk.
Then g o to recovery consdole it is like command propmt.
Then type in command prompt."chkdsk /r"
then press "y"
then it fix eror on harddisk.
Then check.
Jun 30, 2009 | Dell Inspiron 1525 Notebook
System recovery error
WOW, once again the recovery fails when you need it most. I don't understand why the manufacturers don't just give you a CD with the operating system and one with the Recovery when you purchase a system like they did years ago.
Did this error occur on a recovery image that you made (Cd's) or was it from using the Recovery Partition on the hard disk drive that the manufacturer set up? Either way, I think your best option is to just reinstall windows.
Apr 15, 2012 | Toshiba Satellite Pro L640EZ1410 Notebook
When I try to load my recovery cd on an old toshiba tecra 9100 I get an error message about 30% of the way through the recovery . The error msg is ' Error- extraction failed'. Is this a hardware...
Sounds like software problem. Error on extracting the file from the recovery cd to the hard drive. But to make sure, run a diagnostic test for the hard drive if the recovery cd includes that option, if not, try another recovery cd.
Hope this helps.
Jun 11, 2011 | Toshiba Computers & Internet
I get the error message when i try to create media recovery for my laptop toshiba l505. the error messsage is "no HDD recovery area", "the toshiba recovery media creator cannot be...
I am glad to HELP YOU!
When you start to create the RECOVERY MEDIA your machine is creating a virtual file [a temporary one...] that includes all parameters and drivers and system files of your operating system; once the temporary file is done the recovery files are written on the indicated media [a hard drive or a DVD/CD].
Because of the huge size of the file [the temporary one] you need enough room for the virtual file to be created.
So you got your error message just because you DON'T HAVE ENOUGH ROOM on your hard drive.
My suggestion is: find an external drive [a USB attached hard drive] and make the RECOVERY MEDIA there. Meanwhile try to clean up a little bit your hard drive by using that application in Windows called DISK CLEANER [START > ALL PROGRAMS > ACCESSORIES > DISK TOOLS > DISK CLEANER].
My best regards!
... and don't forget to RATE, please...
Apr 19, 2011 | Toshiba Satellite L305-S5907 Laptop
Windows failed to start. A recent hardware or software change might be the cause. file\boot\bcd status 0xc000014c info an error occurred while reading the boot configuration data.
Check the hardware connectivity of your Hard drive and Cd rom drive. Check if the wires are plugged properlyand are not loose. This error is generally thrown when your system is not able to find the boot sector in other words it is not able to find all he information (all necessary file pointers, kernel info And Master Boot Record etc) which it needs to start the system.
In most cases this is a temporary issue and occurs due to loose connections of the cables from Hard drive or CD Rom ( if the system is being booted up from CD).
Nov 18, 2010 | Computers & Internet
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
Sep 06, 2009 | E-Machines eMachines Desktop PC
Feb 25, 2009 | HP Pavilion a1610n PC Desktop
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Wrong Machine Error in Toshiba Satellite L10 101
restart and get into bios setup
then on bios page set to default press f10 save and exit
then with recovery in drive restart press f7 and choose option boot from cd
are you sure you are using a recovery cd that came with your system and not a driver cd for the mother board
if you are still having a problem let me know and let me know any error messages
don;t forget to rate me
thanx
May 14, 2008 | Toshiba Satellite Pro M15-S405 Notebook
Computers & Internet Logo
18 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
