Question about Philips 55PP9401 55" Rear Projection Television
Tv randomly shuts off
Model 55P8341A my tv randomly was shuting off. after letting is set for about 5 minutes it would turn back on. It randomly shut off and now will not turn back on. I have unpluged the set and plugged it back in. the on/off led stays lit up.
  • Anonymous Nov 29, 2007
    my tv randomly shuts off
  • smurf dizzle Sep 26, 2008
    i have the same problem but before that happened i was having problems with picture clarity, and color. Would this be related to the small signal board? i've read that this is supposed to be a common problem with this model.
  • 934 Answers
Replace power relays on power board...
Bill
Posted on Dec 29, 2007
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Tv randomly turns off. Not sure if it is overheating or if something is broken.
It sounds as if you are having problems with the AC Power reaching the television. Please verify the cord is firmly seated the tv's ac inlet
Also check the wall outlet (and power strip) by plugging in a lamp into it and see if it flickers when the tv shuts off.
Good Luck!
Rich Lilja
Mar 21, 2015 | Televison & Video
1990 dakota engine shutting down randomly
I had a 1988 dodge Dakota ,and it did the same thing. I fould that the o2 sensor was bad. I am a self employed mechanic
Oct 28, 2012 | Dodge Dakota Cars & Trucks
Mitsubihsi WS 55311 will not give codes when pressing the input/menu buttons on TV. Tv will shut down in about 5 mins the I canturn it back on. After I press the buttons on the TV it will stay on for a...
This is a V20 chassis and if it shuts down it should trigger an error; note if no error the power light should blink 1, 2 pause and repeat it several times---this is no error found.
I would unplug the set for a few minutes (this clears the error buffer) and turn on again and wait for failure; you must push menu and input and hold for at least 5 seconds and let both go.
IF no error code this is a model made around 2002 (date will be on back of set) and it must display some error code.
If you find none I can suggest looking for any signs of Glycol leaks inside the set. If you need to know what to look for let me know and I will tell you.
Again: All models after 2000 (and some before) have the error buffer.
Let me know if you have questions.
SD TECH
Nov 02, 2011 | Mitsubishi WS-55311 55" Rear Projection...
I have a mitsubishi TV model WS-73411 , a month ago it shut off while I was watching it. Since then it has been shuting off more and more as time goes by. It shuts off an average of 4-5 times at nite...
The next time it shuts down (I presume the green power light goes off) do the self check this model has, on front of set press and hold both the menu and input buttons for at least five seconds and release both.
Power light will blink a 2 digit error code like : 1 blink, 2 blink and repeat it several times.
1,2 is no error detected but there are other codes.
Let me know what you find.
SD TECH
Jun 01, 2011 | Mitsubishi WS-73411 73" Rear Projection...
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
532 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
