Question about Krups Compact Citrus Press
Bought the krups compact citrus press last Christmas. Used maybe four times. Motor is not working. Any suggestions?
Citrus Juicer
The Best Citrus Juicer ' The Sweethome
thesweethome.com/reviews/best-citrus-juicer/
Review by Winnie Yang
Jun 30, 2015 - The Proctor Silex Alex's Lemonade Stand Citrus Juicer was the runner-up in ... The Breville Citrus Press ($130) is a new, lower-priced version of our .... That's not to say fatigue won't set in if you're working on bags of oranges at ... because in this testing round its motor tended to stutter and stall occasionally.
Amazon.com: Dash Stainless Citrus Juicer: Electric Citrus ...
www.amazon.com > ... > Juicers > Citrus Juicers
Amazon.com, Inc.
Rating: 4.5 - ‎114 reviews
Epica Powerful Stainless Steel Whisper-quiet Citrus Juicer-70 Watt motor ... where youpress with your hand, as opposed to having an arm on the juicer to push it down. ....Whenever I take out the parts to rinse then reassemble, it won't start.Missing: stutters
Jan 30, 2016 | Air Purifiers
Please suggest me the tips of teeth whitening for the occasion of Christmas.
After brushing , Gargle with 1 oz of hydrogen peroxide nightly . Do not swallow it. Rince with water.
Oct 21, 2014 | Health & Beauty
Why is my nordictrack T6.3 making loud humming sound all of the sudden?
You don't oil belts as oil will eat away at the rubber. Start with running the machine and checking for lumps of wax build up at rollers (most common issue) if this is not it try oiling roller bearings. But call manufacturer first to see if your warranty is still good because as soon as you touch it it will void warranty.
Jul 18, 2014 | Nordic Track NordicTrack T6.3 Treadmill
Krups XP7230 outgoing used coffee is not compact
Grinder is not working normally and probably inner plastic part which remove coffee from the grinder is broken.
Feb 28, 2014 | Krups XP Coffee Makers & Espresso Machines
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
My customer just bought a CS 1205 from our True Value Store. The blower on the new CS 1205 does not work. It has been used three or four time. The flame comes on however. What do you suggest?
Before call Dimplex Technical Service (888-346-7539) have your customer turn the Master ON/OFF Switch to OFF. Unplug the fireplace for 12 - 15 minutes. Once plugged back in, have them turn the Master ON/OFF Switch to On and then turn ON each function of the fireplace one at a time. If everything is performing as it should, the unit reset itself. However, if this becomes a recurring problem, they should contact Dimplex Technical Service.
Hope this helps you solve the problem for them.
Apr 05, 2011 | Dimplex CS1205 Electric Compact Heater
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
Danby 4.4cuft compact refrigerator
The last time I saw a problem like this, the motor/compressor was bad. If the unit is still under warranty I would contact the manufacture or an authorized repair station in your area
Nov 10, 2008 | Danby DAR483 Compact Refrigerator
Deep Fryer Element Won't Heat Up
Look for the reset button and it should come back on. I just did and lights came on immediately.
Nov 06, 2007 | Rival CZF625 Deep Fryer
Krups Compact Citrus Press Logo
390 people viewed this question
Top Krups Home Experts
Donni Steen
Tom Chichester
Are you a Krups Home Expert? Answer questions, earn points and help others
