Question about Dirt Devil KONE Hand Vacuum MO213BLU Vacuum
Why it won't work
It is plugged into an outlet yet charge light won't come on and it doesn't work anymore
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Euroflex ez2 stop working
Minerals in the water clog up the steam outlet tube on these units. You have to open the unit and look for the outlet from the steam generator and try to unclog with a wire.
...Ummm is there water in the unit (just asking) :)
Nov 21, 2013 | Euroflex Monster Ez2 Steam Cleaner
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Irobot roomba 500
If you're sure the battery contacts are clean and the battery really is charged, then there is faulty circuitry within the Roomba that would have to be repaired or replaced.
Confirm that the battery is inserted with the metal contacts down so they make contact with the spring terminals in the battery compartment.
Visually confirm that the metal contact plates on the battery pack, and the spring terminals in the battery compartment are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
Visually confirm that the metal contact plates on the Roomba, and the spring terminals on the docking station's home plate are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
If you have a volmeter, measure the voltage between the contacts on the battery pack If it isn't something in the neighborhood of 14 volts and is 11 volts or less, the battery isn't fully charged.
Reinstall the battery.
For the moment, please connect the power adapter directly to the Roomba rather than the docking station to eliminate one possible faultly connection.
If the battery wasn't fully charged, or you weren't able to test it, try to charge the Roomba and then retest the battery voltage if you can. If the battery voltage was higher immediately after charging, but didn't get to 14 volts, the charger is good, but battery needs to be replaced. If the battery voltage was unchanged after attempting to charge the Roomba, the charging circuitry may be faulty. If there was no light patterns when you tried to charge it, and it was plugged in to a good outlet, then the power adapter or charging circuitry is definitely bad.
If you have no voltmeter and you cleaned the contacts and tried to charge the Roomba and it works, use the Roomba and then recharge using the docking station and see if it was just dirty contacts or it won't charge through the docking station. If it didn't work, you'll need to figure out if its the battery, the charging circuitry in the Roomba, or the power adapter. If there are no lights when you try to charge the Roomba, then Either the power adapter or the Roomba power circuitry is defective, but without a voltmeter you can't find out which one, and there's no way to know if the battery is good or bad, but you know Roomba wasn't trying to charge it. If there are lights when you try to charge the Roomba, then at least you know the power adapter is good. Unfortunately, without being able to test something there's no way to distinguish between a charger that won't deliver a charge to the battery and a battery that won't accept a charge. If you want to take a guess then a bad battery is more common and less expensive to fix.
Jul 07, 2012 | iRobot Roomba 560 Robotic Vacuum
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
I need the instructions for Black and Decker Start It How do I recharge it?
This unit is recharged using any household 120v outlet. Remove the rubber cap from the recharge port on the top of the unit. Plug the barrel end of the adapter cord into this port and then the put the adapter into the wall outlet. Make sure the power switch is in the off position. To check the charge level push the button to the left of the 3 indicator lights. When the green LED lights up, the unit is fully charged, (yellow is moderate charge and red is minimum charge).
Try to charge the unit from the minimum (red) charge level to maintain the maximum battery life and use of the product.
If you have misplaced the manual I am providing a link to it from Black and Decker's site.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90550872,VEC010BD.pdf
Have a great day.
Jim
Dec 30, 2010 | Vacuums
The on/off buttons are not working anymore? Any
With your hose plugged into the vacuum, check your cord at the outlet, is it securely plugged in? There are no signs of cord damage? If so, you will need to take it to the shop,but it probably just has the wrong sequence in the power buttons.. turn on the main unit switch then turn on the hose switch to the canister, if no power, then hit the switch on the machine again, it should power up, if it does not, open up the bag compartment, and shut it again, making sure that the bag is aligned inside and the cover is closed tightly. Did this fixya? Let me know. You may need to contact electrolux for a replacement hose. they are really good about warranty service and will send yu a new hose at no charge if they determine that is the problem. Here is some contact info. Thanks, Rene(the Vacuum Doctor)
http://smallappliances.electroluxusa.com/node47.asp
Nov 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The unit won't charge after plugging in to outlet.
Its the battery cell, its dead and unable to hold a charge. you will need to purchase another cell.
Feb 16, 2009 | Scunci 52033 Canister Wet/Dry Vacuum
Dirt Devil KONE Hand Vacuum MO213BLU Vacuum Logo
37 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
