Question about Dishwashers
Lock light will not turn off kenmore ultrawash model 17772990
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Ultrawash Quiet guard 3; can't get the
Try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on.
Let run for a little bit. then keep pressing the start button... until the unit shuts off, then try running a cycle.
The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking there is something wrong with your heating cycle.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Aug 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: I have a Kenmore Ultrawash
Hi
Thanks for using FixYa. To resolve this press and hold the No Heat Dry/Air DRY button for 15-20 seconds, if this won't resolve the issue then you'll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 13, 2010
Daniel S
  • 4323 Answers
SOURCE: the control lock light will
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 11, 2011
Kenmore Elite dishwasher takes water and discharges it, but will not start washing.
You must have a control panel problem, nothing else I know of causes this.
Sep 21, 2016 | Kenmore Washing Machines
Kenmore ultrawash diswaher model 665.1374 cycle and options buttons light up but start button does not light and diswaher does not start. please help
Check that the door is closing all the way and that the latch isn't damaged or bent. It sounds like a door switch issue.
Apr 04, 2015 | Kenmore Dishwashers
Why is the lock light on
Look on the front for the buttons that say lock press them at the same time and hold for several seconds the light should go off. If that won't work try to turn off the power for several minutes then restore power.
May 14, 2014 | Kenmore 24" Built-In Dishwasher with...
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
I need the reset button sequence for a Kenmore Ultrawash automatic dishwasher Model # it is 665-15772990. My daughter was playing with all the lights and the only thing it will do now is drain.
I had the same problem and this fixed it:
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 14, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore ultrawash dishwasher
little nip Most likely the problem with your dish washer is one or more pads on the control panel are shorted. To fix it the control panel has to be replaced. If you are going to do it yourself, I need the complete model number (on the door frame) and the color for the panel. Then I can find the best deal for you. Gendos...post back
Feb 01, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
