Question about Western Digital Scorpio WD1600BEVS 160 GB IDE Hard Drive
How to open wd1600bevs - Western Digital Scorpio WD1600BEVS 160 GB IDE Hard Drive
    Habit-Forming:
  • 72 Answers
Dont open your hard drive. precision components will be ruined if opened in anything other than a cleanroom environment.
Posted on Feb 12, 2015
WD1600BEVS Scorpio pin settings
You shouldn't have any problems. The computer uses SATA drives and the drive is SATA and is also a 2.5" laptop HDD. Make sure that you have a way to install an OS , etc
Nov 13, 2013 | Western Digital WD Scorpio Blue WD1600BEVS...
Hello! I have a new hard drive WD1600BEVS, problem is that, when I`ll try to install windows 7, all stop at stage where I have to choose place where to install this program...and there ask for drivers for...
had same/similiar problem
if your computer is asking for a driver when you insert the windows 7 disc your motherboard might not support windows 7 if its older than 5 yrs also you need a minimum of 2 GB of ram to support windows 7
hope this helps
Sep 01, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
Wd scorpio blue 160 gb how to reset
Reset it or format it ? cause there is no reset for hard disks.
Is your hard disk operational ?
Jul 29, 2011 | Western Digital WD Scorpio Blue WD1600BEVS...
WD1600bevs drive not seen by windows. Disk cloning software saw drive but thought it was a 2 TB drive.
Are you trying to install a new hard drive for new storage space or are you trying to move a hard drive with files on it that you intend to keep?
New drive with no files:
Right click my computer and select manage, choose "disk management" in the left pane, see if there is a drive listed with "unallocated space", if so, partition the drive, format it, and windows will assign it a drive letter.
Drive with files to keep:
Upon starting your computer, enter the BIOS or "setup" (usually by pressing f2, tab, escape, or some other key...but it should tell you what key to press), make sure the drive is detected in the system bios (make sure the SATA port that the drive is plugged into is turned ON) . Make sure the drive is plugged into power as well as data. Try a known good SATA cable.
Feb 23, 2011 | Western Digital WD Scorpio Blue WD1600BEVS...
I have a WD1600BEVS - 60RSTO 2.5 inch HDD that came with my HP Laptop. It wasnt booting and since it was old, i took it to a friend of mine who said he'd try to repair it. I already had a 250GB replacement...
Hi.
If the hard disk been opened unfortunately you lost your data. You can try to send it to a data recovery company but it will cost few thousand bucks to get your data out of the disk plates.
Opening a hard drive to check it out is 99.99% chances of fail because of dust. If you can fix what was wrong and put everything back together and plug it the head will hit the dust at 7200 RPM and it's like a plane crashing on a mountain.
Good luck anyways.
Vince
Feb 22, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
Fogit it - you are fcked.
Only alternative you have at this juncture is to avail yourself of a data recovery service at great expense.
Sometimes a repair operation or diagnostic test on a finicky drive could permanently trash the unit or make it worse. That is apparently what happened to your drive.
In the future this incident should impress on you the fact that a hard drive backup of important data is always a must. All hard drives from the moment of manufacture start to die - we just do not know when!
Jun 19, 2017 | Western Digital Scorpio WD1600BEVS 160 GB...
I bought a new WD1600BEVS drive to go in a laptop but when I put it in and try to install Windows XP it only shows 54GB available out of the 160GB on the drive.
Tell the Windows Install to DELETE the current partition.
Then, tell it to create a new partition, and it will use the entire 160GB.
Sep 18, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
I have a Toshiaba laptop which had a hard drive failure , so I installed a new Western Digital Scorpio WD1600BEVS 160 GB hard-drive. When I tried to install Windows OS, the installation failed to detect...
You can install the windows to follow this step.
Make sure that the CD drive is on first boot. When you turn on your laptop you need to press the delete key fast, to access the BIOS. Once you have change the BIOS settings you need to save it. After you save once the laptop detecting the windows CD press the enter key fast also to boot from CD.
Jul 27, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
I did delete partition of drive 0 Acer 7720G
Go to Control Panel > Administrative Tools > Computer Management > Storage > Disk Management (Local). Choose Drive 0 and right-click on it. Choose "Mark Partition As Active".
That should fix it. You may have to format the drive after all.
Dec 31, 2009 | Western Digital Scorpio WD1600BEVS 160 GB...
Laptop not detect external hard disk
Connect the external disk-drive to some other computer, e.g., a desktop. Does it work, or is it still "dead" ?
Nov 01, 2009 | Western Digital Scorpio WD1600BEVS 160 GB...
Western Digital Scorpio  WD1600BEVS 160 GB IDE Hard Drive Logo
66 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
