Question about APC Computers & Internet
I need a program for my computer run a ups es 350
I am looking for powerchut personal edition
    Problem Solver:
  • 7 Answers
Powerchute personal edition is available for free download from APC. Does your ups have a USB port? The software is useless without it.
Posted on Jul 03, 2014
How to monitor Matrix 5000 UPS via email?
Try using use the agent and server of the Powerchute plus and the console of powerchute business edition run from another PC.
You may need version 9 or later of PBE.
Jul 29, 2014 | APC Matrix-UPS 5000 UPS System
HOW DO I KEEP MY MINUTE MAN BACKUP TO STOP BEEPING?
If you connect it up to a Windows computer with the supplied (goofy-looking) USB cable and install the APC Monitor progam "Powerchute" available on the APC web site, you can set all the activity levels and tell it just when to beep the beeper, or turn it off completely. I have two of these in my house, and have set them to never beep. The cable is goofy because it is USB on one end and a network-type on the other end.
Software Firmware
Jun 28, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
I am looking for a program powerchute personal for es 350
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BK350&total_watts=200&tab=software
First download option should be the software you are looking for - if that doesn't work reply with the exact model number of the UPS.
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Nov 21, 2013 | Computers & Internet
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC 1100CI-IN UPS NOT EORING ON GENERETOR WHAT I DO? PLZ SEND SULATION E-MAIL singhpintu987@gmail.com
Hello Sing,
There is a possibility that your UPS doesn't like the voltage or frequency that the generator is feeding it. As per an APC knowledgebase article, the size of a generator should be 3 to 5 times higher that the total Watt/VA load that it would be supporting.
There are also instances wherein the sensitivity threshold of an APC BackUPS is set too high that a slight change in voltage/sensitivity would cause the unit to switch from online to on battery too frequently. This can be addressed by lowering the sensitivity either by their APC PowerChute Personal Edition Software or via the front panel switch.
If you are going to do it via the software, it needs to be installed on your computer. Prior to downloading it, make sure that your operating system is compatible with it. Suppose that your operating system is compatible, once the program is installed you will need to open it up and look for the Sensitivity option and from there you could select Low, Medium or High.
If you are going to do it via the front panel switch/button the UPS should then be turned off but plugged in to an input source. Press and hold the On button until you see that the LEDs are flashing. Once the LED is flashing, press the button again to set the desired sensitivity. Low sensitivity would show the On Battery LED flashing. Medium is On Battery and Overload LED while High is On Battery, Overload and Replace Battery LED flashing. If you'll see a flashing Online LED it means that you are cancelling or exiting the program mode of the UPS.
Below are some helpful links from APC
*** You will need to login in APC before you can download the software. Choose the correct PowerChute Personal Edition Compatible with your OS and create an account online.
Jul 22, 2011 | APC Back-UPS CS 500VA UPS System
Cannot open 2007 es 350 trunk
REMOVE TRUNK SWITCH INSIDE CAR,JUMP WITH PAPER CLIP AND CHANGE SWITCH,IF THATS NOT IT,PROBABLY COMPUTER KEY NEEDS TO BE PROGRAMMED AT DEALER.
Jun 01, 2011 | 2007 Lexus ES 350
Windows 7 Home Premium will not recognise the extension .ES$ which 'Expert - Personal Roots' applied to an old program which used Windows 95. Can W7 run such a program ?
No - the program is too old. But you can do something else: You can install a Virtual Machine program, like
http://www.microsoft.com/windows/virtual-pc/
in 7, in the virtual machine you can install Win95 , in it you can install the program Expert - Personal Roots and with it open your file and save it in another generic format.
Nov 26, 2010 | Computers & Internet
Personal Antivirus has invaded my computer. I have went to several websites and learned that it is a scam and that they just want to sell me software. I cannot remove this through add / remove...
Kill processes:
pav.exe
unins000.exe
Delete registry values(go to run and type regedit):
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Personal Antivirus_is1
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_ITGRDENGINE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ITGrdEngine
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer "PrS"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Personal Antivirus"
Delete files(use the search function to find files):
Personal Antivirus.lnk, Uninstall.lnk, pav.exe msxmlm.dll.tmp, drv1878004.exe.tmp,
Delete directories:
c:\Documents and Settings\All Users\Start Menu\Programs\Personal Antivirus
%UserProfile%\Application Data\Personal Antivirus
%UserProfile%\Application Data\Personal Antivirus\db
c:\Program Files\Personal Antivirus
c:\Program Files\Personal Antivirus\db
c:\Program Files\Personal Antivirus\Languages
(Where %UserProfile% is C:\Documents and Settings\Your username or C:\Users\Your username if you use vista)
reboot
Sep 19, 2009 | Microsoft Windows XP Home Edition
You should change to battery or switch to power outlet
This is typically caused by software that manages an uninterrupable power supply (aka UPS). Simply put, this is a battery that the server plugs into to so the server can run for a short time when there is a power outage.
UPS devices frequently come with software to communicate with the server so it knows when it is on battery. When the server is notified that it is on battery it will provide warning messages like the one you described. Some will even pass the notice to all computers connected to the server to make sure no work is lost.
One of the most popular programs is APC PowerChute. I would look for this program or other programs that have the words "UPS" and/or "power" in their name to find the cause.
I hope this helps.
Jun 25, 2009 | IBM eserver xSeries 205 8480
APC Back UPS 350 ES won't run on battery power.
>> I'm having the same problem with mine. I get 122 volts when plugged into the wall, and it tells me that I get less than 1 min of use once I unplug, and it actually lasts for 10 seconds before getting a screeching sound.
The screeching sound is normal. Its telling you "HEY, I HAVE NO POWER. THIS IS A PROBLEM." and trying to attract as much attention as possible. It will also do that if you run a self test with the software and the test fails.
Its been a while since I worked on these during an outage, but I believe there is a way to use the software (PowerChute business edition, if you're using a SmartUPS. There is a personal version with less features for other home models) to silence the alarm. I think some of them had a button you could push on the unit to silence it as well, but look this up first. Push the wrong one and it powers everything down.
Feb 17, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
Computers & Internet Logo
50 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
