Question about Pro Signal Universal Television Stand, For Televisions 17"
Where to purchase pro signal television stand
Where can i purchase pro signal tv stand 17"
Looking for stand flat television 17" rld1730
sadly there is nothing we can do here on FIXYA about you needing to buy a larger stand for your television .
Aug 03, 2016 | Televison & Video
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Trutech tv - no sound, but have picture
Check if you would have the same if you use a different signal source. Another DVD Player, a playstation or other AV devices. The source or the TV may not be understanding each other, one may be sending analog signals while TV is only recognizing digital.
Oct 10, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Purchased TV without stand
You could try calling this number 866-965-3842 its a 3rd party repair center that services Olevia televisions.. but they might be able to sell you a stand..
Jul 06, 2009 | Syntax Olevia 537H Television
17 in. trutech tv unable to get channels except 2-13
For channel setup you will need to;
1) Connect the signal source to the back of the set.(Antenna or Cable)
2) Go into the TV Menu and select the same signal source you connected to the back.(Antenna or Cable)
3) Go to the auto program/scan menu and run it. This may take a few minutes.
Now the channels may be watched.
Mar 16, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Protron PLTV-26 Television
Here is the number to Spectroniq, which is the manufactor of Protron, you should be able to purchase one from them directly.
1-877-778-8876
Aug 18, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Trutech tv and computer hookup
Press the function key on your remote and then the up/down button and change it to PC. Also you can adjust the PC screen by going into the TV Menu then into settings then PC
Mar 22, 2008 | TruTech PVS31170S1W 17 in. LCD Television
Samsung
On the back of the tv at the top of the stand will be four silver screws, remove those with the set laying on it's face or the tv may fall over. after those are removed the stand will slide out of the bottom of the tv. Hope this helps.
Mar 11, 2008 | Samsung LTM1755 17 in. HD-Ready LCD...
FUZZY (SNOWY) PICTURE
Well, I can tell you it shouldnt have anything to do with your not having an HD box. The TV does not require a HD signal to give you a quality picture. The HD box only gives you the enhanced HD signal, but should work as any regular TV without it. How do you have it connected?
Dec 24, 2007 | Memorex MT1701 17 in. HD-Ready LCD...
Pro Signal Universal Television Stand, For Televisions 17" Logo
79 people viewed this question
Top Pro Signal Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Pro Signal Furniture Expert? Answer questions, earn points and help others
