Question about RTO Cybex 520T Remanufactured Treadmill
I have a Trotter 400T treadmill. It began making a high pitched noise while plugged in but not being used. None of the switches would work so we unplugged it to stop the sound. Left it unplugged for a couple days, plugged it back in, then it worked again. Then later that day begain making the noise once again. We have now unplugged it again and it will not start when plugged back in. Just makes the loud high pitched sound
4 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: I get the worse electrical shocks from my
Better check the harness where it runs up the supports. Some of these had the harness mis-routed and screws were able to damage the wires and create shorts.
Posted on Apr 28, 2010
ercupa190
  • 12223 Answers
SOURCE: My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Posted on Jul 23, 2012
ercupa190
  • 12223 Answers
SOURCE: my sole treadmil makes noise when changing levels
1) Lube the deck belt, very well, maybe you have WORN deck belt, time to replace, this happen because the lack of maintenance schedule.
2) LUBE the roller bearing TOO.
3) Measure the input voltage motor, if there are voltage , the motor NEED repair.
God bless you
Posted on Oct 15, 2012
My trotter 510 treadmill doesn't turn on and just gives off this high pitch sound when turned on
oh, the trotter treadmill that is a workhorse of a treadmill. Question doubled edge. does it start?? or it does not Start. the sound if it does turn on may be coming from the motor which may need new brushes. Trotter is now Cybex fitness. they will have a part to make the repair
Oct 12, 2017 | Exercise & Fitness
The wire on the back of the tridmil triumph 400t came off and it want light up and you can here that it's on but it is not running.
Triumph™ 400T Treadmill ' Academy
www.academy.com > ... > Cardio Equipment & Machines > Treadmills
Rating: 3.4 - ‎67 reviews - ‎$259.99 - ‎Out of stock
The Triumph™ 400T Treadmill features a 1.50 CHP motor and the AEROsoft™ cushioning system.Missing: motorcycles
Triumph 400T Treadmill - YouTube
? 0:31
https://www.youtube.com/watch?v=TZdf5fIAVMU
Jan 4, 2012 - Uploaded by Academy Sports + Outdoors
Visit Academy Sports + Outdoors or academy.com to view theTriumph 400T Treadmill which is featured at a ...Missing: wire ‎back
Triumph - 400T - TM397B - 2011 - FitnessRepairParts.com
Dec 26, 2015 | Triumph Motorcycles
Cybex 520t error 6
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 6 is a motor over voltage error. Motor voltage exceeded 200 VDC for 200 milliseconds. This can be caused by a worn deck and belt due to a lack of routine maintenance. AKA adding wax between your deck an belt. You might be able to wax your machine and make the error go away. More than likely a new deck and belt will be needed. Using the link below and your model and serial number, you can find the needed items. In worse case scenario, you may also need a new motor control board.
Repair Parts for Trotter Cybex Treadmill 400T 410T 500 Series SPORTSMITH...
Apr 07, 2014 | RTO Cybex 520T Remanufactured Treadmill
Cybex 530t error 6
Jan 20, 2014 | Exercise & Fitness
Key pad enter + numbers not working trotter 685
adjust the reed switch, test for open or faulty, clean it, and tight the connector fery weel , see the diagram attached
2) replace the batteries old by new ones, and clean the contacts batteries.
3) tight the ribbon cables for keypads, clean it too.
God bless you
Feb 22, 2013 | Treadmill Doctor Cybex Trotter685 900t By...
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
All my Dell power adapters are dying! I have 3 and none work now. The first one started saying it was not compatible, then the next one worked for a short period then the green light went out. I put one...
Yes! unfortunately it is, the reason why the power adapter has the high pitch noise is because the power supply is being loaded down by the motherboard, it may be due to the DC jack in the laptop or the charging circuits on the motherboard causing the problem. However there is one way to find out, remove the main battery to see if the high pitch noise goes away, if it does! it will prove where the problem is. It is also very possible that the battery is loading the whole circuitry, because it may have a high resistance short, enough to cook the power supply, I have seen this in very rare cases and is one for the books.
Mar 11, 2011 | Dell Inspiron 5100 Laptop
I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
RTO Cybex 520T Remanufactured Treadmill Logo
119 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
