Question about Acer TravelMate 5520 Notebook
Acer travelmate 5520 startup 45-second-trick
What is the 45-second-trick
janelu
  • 93 Answers
SOURCE: acer travelmate 5520 bluetooth not working
Make sure there is a Bluetooth device physically installed in your laptop, it could be check from your purchase paper...
Posted on Nov 13, 2008
  • 17 Answers
SOURCE: Acer TravelMate 5520 is bio-probtected and unknown password
As a general rule, registering with "Acer Standard Registration" is simply putting your computer under Acer's warranty for operation and/or repair if needed; registration almost certainly has nothing to do unlocking your password.
First, without sounding critical, if you didn't set the bio-protection, who did? Or, who had access to your computer that could have set the biometric fingerprint sensor? That person could/should be able to unlock it.
Assuming you've used the computer (and not someone else) and you're not the second register of the computer, you could try contacting Acer at their website and explain your problem and see if they can answer your question.
If the laptop is not originally yours, and the biometric sensor was set by a previous owner, that should solve your problem, having the previous owner "unlock" the system.
If the laptop is not originally yours and you don't know who the previous owner is, there's a good chance that you cannot access the informtion. You could take the laptop to a computer repair outlet that does hard drive repairs, however that is usually not cheap and you might pay for them for an evaluation and find that they cannot unlock the system.
And, there's a chance that you will not be able to reformat the disk; the protection might not allow you to reformat it. Again, you might need to bring it to a computer shop and have them reformat it (or, possibly, install a new hard drive in order to use the computer).
XMinusOne@gmail.com
Posted on Dec 10, 2008
  • 39 Answers
SOURCE: Acer aspire 5520 laptop. Is it dead?
To verify it isn't a battery issue you can try taking the battery out completely and plugging in the A/C adapter and turning it on.
Without more information it's hard it's hard to diagnose your issue more specificially. Do you get any lights on the front?
Posted on Jun 21, 2009
SOURCE: how do i reset my acer travelmate 5520 to factory
start computer when acer logo appears press F2 to go into BIOS settings scroll across to BOOT top menu bar with the arrow buttons scroll down to D2D enable/disable change to enable and ENTER. save and exit. restart computer once again when acer logo appears press <Alt>+<F10> at the same time to enter the recovery process, refer to on screen instructions to recover system.
Posted on Jan 27, 2010
SOURCE: acer travelmate 5520 cant turn on bluetooth
Please vist the link below to determine if the computer has bluetooth
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire1300/Aspire1300faq37.shtml
Posted on Mar 18, 2010
45 second trick
What does this have to do with PC laptops ???Please post in correct category.
Jun 27, 2014 | Acer TravelMate 5520 Notebook
Acer 5520 travelmate when loading has 2 vista partitions how to delete one
when you boot to your normal partition can you see the other vista drive?
this can be a restore partition so it is worth keeping but to answer your question.
go to my computer right click manage and go to disk management.
in here you should see all your disks like C:\ D:\ and E:\
now when you partition it creates a new drive letter but remains on the same disk. you will have to manually check to make sure which partition you want to delete, once you know right click that partition and click delete
Feb 01, 2012 | Acer TravelMate 5520 Notebook
I have an Acer travelmate 5520. Sometimes when I boot the screen comes on, then othertimes it doesn't. Help please!!
there is a tiny button that turns off the screen when the notebook is running with the lid closed sometimes they may stick, check this
Jan 24, 2011 | Acer TravelMate 5520 Notebook
Acer travelmate 5520, when you start is white screen after 20 seconds and stops
Test the laptop with a external monitor see if you get any picture on the external if the external screen remains white then most likely the mainboard or the video adapter (in most cases build into the mainboard) is failing or has failed. One Possible reason could be overheating damage (the unit may not be overheating right now during the 20 seconds, it may have suffered earlier).
It could also be a poor connection between the display and the mainboard. but if the screen works for 20 seconds and then goes white its probably not the issue.
If the external screen works without any problems the issue is most likely your lcd screen or one of the boards inside.
If you are in warranty get in touch with your dealer or acer.
If you are outside of warranty get in touch with acer or a local repairer / acer cervice center.
Thanks,
Ekse
Aug 14, 2009 | Acer TravelMate 5520-5678 Notebook
Printer wont install on acer travelmate 5520
Yes, you usually need a driver for printers. You can get the drivers from the website of the manufacturer of the printer (eg. www.hp.com)
Jun 12, 2009 | Acer TravelMate 5520 Notebook
Why can't I hear audio when I play my cassette player plugged in to the line-in jack of my Acer Travelmate 5520
You need some form of software to port it out. Basically, you can use windows sound recorder and hear it for the duration of the recording and play it back that way but it's only 30 seconds at a time. You need software to feedback the audio all the time. Maybe DJ software or something like that would do the trick.
Nov 12, 2008 | Acer Computers & Internet
Acer TravelMate 5520 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
