Question about Amana NED4600YQ Electric Dryer
Need to know how to wire up my amana ned4600yq1 electric dryer
Im having trouble wireing up my amana dryer it has a red, white ,black , and another white going to the ground on the machine
aborcass
  • 2651 Answers
SOURCE: Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Posted on Mar 18, 2008
Illeagle
  • 525 Answers
SOURCE: amana dryer led20aw need wiring
Below is a link that will provide you with a wiring manual.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Hope this helps!
Dave E. (Illeagle)
Posted on Jun 15, 2008
SOURCE: Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Posted on Nov 06, 2008
jsrock516
  • 5911 Answers
SOURCE: I need to change the dryer power cord on my Amana
The two wires on either side of the power cord are your HOT leads. They are the voltage carrying conductors. These two wires will connect to the terminal block on the RED and BLACK wires. The middle wire is NEUTRAL and goes to the WHITE wire at the terminal block. Now...with a 3-wire configuration you will need to connect a grounding strap to the neutral wire and ground it to the grounding lug of the appliance. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between 3 and 4 wire configuration is how the neutral and ground wires are installed. In a four wire configuration these two are independent of each other. In a 3 wire configuration ground and neutral are connected together.
If you have any questions about this repair, please ask me. I hope this helps you.
Posted on Jul 17, 2009
kel1guy2002
  • 3740 Answers
SOURCE: power wire troubles
See page 7 of this .pdf manual:
http://www.servicematters.com/maytag_library/docs/RS3200007R0.pdf
It will show you both 3 and 4 wire connections for your dryer.
Thanks for using FixYa.
Kelly
Posted on Jun 06, 2010
How do you install electric cord on dryer
red & black from the cord to the 2 outer terminals on the dryers terminal block either wire on either terminal,then the white wire from this cord to the center terminal between the red & black wires and finally the green safety ground wire to any portion of the metal dryer chassis
May 12, 2012 | Amana Dryers
Has an extra white wire that I do not know what to do with in a 3 wire connection
Good day,
White wires are always a neutral. They should be attached to the center post. Here's a look.
This is a 4 wire settup.
This is a 3 wire setup.
Nov 03, 2010 | Amana NED5200TQ Electric Dryer
I need to change the dryer power cord on my Amana NDE6800AYW dryer. The current cord is a 4 prong with four wires that are black, red, green, and white. I need a 3 prong plug and I got a cord a Home...
Jul 17, 2009 | Amana NDE6800AYW Electric Dryer
I need to know how wires on the power cord connect
Red on the left.
White in the middle.
Black on the right.
Green on the case/chassis ground or green screw with the small dashes on it.
If you don't have a white wire but the the green in the middle position.
White/red = far left
Green = middle
Black = right
Jan 29, 2009 | Roper REX4634KQ Electric Dryer
Amana dryer, changing out the electrical plug from 3 to 4 prong
For example; Green wire goes to green screw on machine. White in the middle, red on left, black on right. (observed small color coded wires connecting in back-ground as well.)
In general, each color should match. Meaning, white with white.
Jan 27, 2009 | Dryers
I own an Amana Heavy Duty dryer, model # NDE880AYW, and I'm trying to change a three prong cord for a four prong cord. I know nothing about electricals so I need help at a very elementary level. I have...
First off. Do any and all electrical connections with the PLUG detached from the wall receptacle.. The Green Wire is earth ground and should be connected to the nearest Chassis or Frame terminal.. There should be one near the terminal block for the two power ( red & black) and one neutral ( white).. It's OK to double up the green wire with other green wires.. so your answer is YES.. connect it to the nearest Green wire terminal.. This green wire provides protection to you and anyone else from getting electrocuted by bonding the frame/chassis as well as other sheet metal parts to earth ground.. Hope that helps...
Aug 24, 2008 | Amana Dryers
Replacing a pigtail
You hook the Red and Black wires to the gold colored screws on the dryer, and the white wire goes to the siolver colored screw. The Green wire goes to the Body.
Sep 19, 2007 | Amana DLE330RAW Electric Dryer
Amana NED4600YQ Electric Dryer Logo
225 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
