Question about Whirlpool Duet GHW9150P Front Load Washer
Duet will not start has power no error msg and door is shutting
  • Whirlpool Master
  • 17,130 Answers
Possible fault with the control panel
Click for tips on : control panel
Posted on Nov 21, 2013
How can i fix my C6180 HP photosmart computer with msg of improper shutdown from wall switch
Try what they call a hard boot. In other words completely power down ththe printer by either removing the power cord or shutting down via the power button. If this does not work try to enter the menu and clear the arror code manually. Hope this helps.
Sep 08, 2012 | HP Photosmart C6180 All-In-One InkJet...
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cannot get washer door to open.
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
