Question about Mitsubishi WD-73638 DLP TV
Power supply for mitsubishi wd-73638 dlp tv - Mitsubishi WD-73638 DLP TV
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
  • 192 Answers
SOURCE: electrical chasis cooling fan for Mitsubishi wd 52525
There are several Parts Houses that carry this part. The one I think that is the easiest to deal with is Andrews.
The URL is:
https://dealer.andrewselectronics.com
Can't find it there, reply to this post and I will respond.
Posted on Dec 15, 2007
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
rulds2008
  • 3866 Answers
SOURCE: cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Posted on Jul 01, 2009
I need a 73' tv screen for a mitsubishi model wd=73638
Contact the authorized service center for Mitssubishi. It can't be purchased from open electronic spare part market.
Electro help
Jul 20, 2014 | Mitsubishi WD-73638 73 inch DLP 1080p...
HOW DO I ENABLE 3D
Assuming you have a 3D TV, AND either a service offering 3D programming OR a 3D BluRay player AND a 3D BluRay disc, AND it is properly connected via a suitable HDMI cable and port, AND the required 3D glasses... you turn on 3D according to the specific instructions of your TV!
Jul 01, 2014 | Mitsubishi WD-73638 73-Inch 3D-Ready DLP...
Mitsubishi WD-73638 no picture and shuts off randomly
I would think that the item to check would be the power supply. You will have to take the TV apart, get the board part number and see if you can find a replacement for it. I would recommend putting a meter to it to verify it is the board that is bad.
Mar 12, 2014 | Televison & Video
Mitsubishi 73"DLP wd-73638 won't turn on after power outage or getting unplugged
In most cases, this can be due to curropted software [firmware]. Contact the authoriized service center for Mitsubishi. Please do not try to update the software by yourself. It is a very skilled work to this set. Gopakumar Gopalan Google
Feb 24, 2014 | Mitsubishi Televison & Video
I have perfect picture but no sound??
Many Mitsubishi TV have an audio mute button on the back of the set. It is near the audio out RCA connector and is used to disconnect the internal speaker when an external speaker is used. Just press the button and the internal speaker will work.
Sep 16, 2013 | Mitsubishi WD-73638 DLP TV
I am trying to connect my hp laptop to my '73mitsubushi tv with an HDMI cable. TV says wrong format. Help!
you have to select the monitor out on the computer is ether the f1 or f2 key on the laptop
Feb 12, 2012 | Mitsubishi WD-73638 DLP TV
Mitsubishi WD-73638 DLP TV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
