Question about Norelco Quadra 7617X Electric Shaver
Off/on button switch is loose or broken. can it be replaced?
I've got a beko DCU7230w tumble dryer, start/pause button is loose and won't push in to start the dryer
The most common fault her could well be it has got broken at the inside of cabinet With plug unplugged take off lid from dryer check to see if its came slack,/broken tighten or replace switch replace lid & try should be job done
Feb 04, 2016 | Dryers
How do i fix power button switch on my wireless bluetooth headset? it the LG tone HBS-700
It is possible you may have broken the power switch off of the circuit board. To find out, you will need to open the earpiece and inspect it. Here is a video on how to open the earpiece LG Tone HBS700 730 repair mod and upgrade. If it has broken off, you may be able to solder it back on to the circuit board. If it is beyond repair, you could purchase a broken earpiece for cheap and use this video to repair it.
I hope this helps.
Feb 13, 2015 | LG HBS-700 Bluetooth Headset
Power button isn't working, but light is on inside when door opens
see the diagram attached:
You must test 1) Push button for open or dirty contact, clean and tight the wires for loose, burn, or broken. 2) Test the door switch for open or faulty switch and replace 3) After you did replace or are o.k and the problem remain the same, the motor winding or switch is defective repair.
Jun 06, 2012 | LG DLEX3070R SteamDryer Series 7.3 cu. ft....
My power button on my Gateway ML6232 is loose
Keyboard/Hinge Cover with Power Button Bezel,
http://www.laptopswer.net/products.php/GATEWAY_ML6000-MT6000_POWER-BUTTON_3CMA7KBTA07/cPath,1_97_102/language,en_US/osCsid,8d147ed2c28ef93651edc40940d868e7
The Power On switch is not part of this small cover. The Power On button that you see, is merely a little button cover. The actual switch is under it, and mounted to the laptop.
[ The Power On switch is a Momentary Contact Switch.
Much like this example of an ATX power on switch,
http://www.directron.com/atxswitch.html ]
Removal and Replacement of the Hinge Cover with Power On bezel:
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) This strip cover pops up. It has small plastic protrusions, or tabs molded on the outside edges.
These tabs snap into place in the Palm Rest Cover.
I use a small flat tip Jewelers screwdriver, and ease up on the end opposite of the Power On button. Then carefully go along the edges.
Replacement is to just line it up, and snap back into place.
Regards,
joecoolvette
Jan 14, 2012 | Computers & Internet
Etrex enter button does not work
It may be the tactile switch that is broken. I had the same problem on my older model etrex. I carefully removed the surrounding rubber case wrap and the sticky tape underneath. This allows you to visually inspect the switches. The black plastic button on the enter switch was completely gone and the buttons on the page up/down keys were broken away and loose, although those keys still worked. I opened up the case, removed the switches (largely by using a razor blade to pry them off), and bought 8 replacement switches from mouser (667-EVQ-PSH02K). I replaced the three broken switches using a very fine tip on the soldering iron with flux on all the feet. The extra switches I will keep for further repairs if necessary.
Oct 04, 2011 | Garmin eTrex GPS Receiver
I have a 2003 kawasaki 1500 nomad i have no power to the headlight or to the switch fuse is good power in and out of the fuse. I could use a wiring diagram
try cleaning your starter button. The starter button is a two position switch. First it turns off the headlight , then, it activates the starter solenoid. take apart the switch and try cleaning the contacts with alcohol. If the the button is broken you will have to replace the right switch assembly to fix a button issue. If the button checks out then open the headlight bucket and check the wire connections. A loose wire plug in or an internally broken wire could also be the culprit. Check the button first then go after the wiring.
May 06, 2011 | kawasaki KX 85 Motorcycles
I am in need of help. For some reason my brake lights come on all by themselves. The car will be sitting in park, not on and the lights just come on. I have to go and hit the brake petal to get them to...
check brake light switch where the brake pedal arm is.the brake light switch is loose or broken.or bracket holding brake light switch is loose or broken fell out of position. the brake light switch suppose to be touching the brake pedal arm to turn off brake lights.if switch not touching pedal arm.switch is broken,if brake switch touching brake pedal arm,and brake lights still on.replace brake light switch.
Apr 06, 2011 | 2001 Pontiac Aztek
Hi, I have a Toshiba M200 Satellite model. since two days the laptop is not switching on and before this for a week it use to get switched on after pressing the power switch number of times. Also, tried...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 09, 2010 | Toshiba Computers & Internet
Power button loosely slides
Yes. The switch has broken and is replaceable. However I wouldn't recommend you do it unless you've done this before. DS Lites are easy to damage further when taking them apart. It's a great system but is easily broken beyond fixing. Look at all the posts on here from people putting new shells on and now the system won't boot up, broken ribbon cable connectors, etc. If it's under a year old contact Nintendo and they will repair it for free.
Mar 08, 2008 | Nintendo DS Lite Console
Norelco Quadra 7617X Electric Shaver Logo
16 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
