I have a sharp atomic clock SPC1005. When I changed the batteries, the transmitter no longer works. How can this be fixed?
The inside temperature reads, but the location for the outside temperature just shows a couple of dashes.
  • 3 Answers
SOURCE: outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
Posted on Jan 15, 2009
SOURCE: Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Posted on Jan 18, 2009
SOURCE: I have a skyscan atomic
This is a very common problem that is most frequently caused by the outdoor transmitter going bad. They are surprisingly delicate and don't like getting wet.
You can order replacement transmitters from http://skyscan.info/content/
They only cost $11 and that includes shipping and handling.
Posted on Feb 07, 2009
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Posted on Apr 13, 2009
SOURCE: I have a barolo atomic clock, batteries went
Make sure the day is displayed instead of seconds, then homd down the + button for 5 seconds. Every 5 seconds should advance it on zone. Had same problem and just got done resetting mine this way.
Posted on Jul 17, 2009
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 | Home
Outside temperature not working on Atomic Clock (was working last night). Changed the batteries in both the outside transmitter and the clock tonight. Clock reset within minutes, but the outside...
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | SkyScan 86709 Atomic Wall Clock
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Sio/Scan Temperature Transmitter 433MHz for batteries
I just changed the batteries yesterday. It was hard to open the battery compartment with bare hands/finders. I used flat screw driver to poke into the notch in the center of the transmitter. Or you can try poke into any **** around the compartment. It works!
Feb 17, 2010 | SkyScan 86709 Atomic Wall Clock
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
Outside temperture
Nov 19, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
148 people viewed this question
 Grubhead
Grubhead
