Question about Kodak EasyShare C653 Digital Camera
Dropped camera I dropped my camera on the carpet floor in the house, i switched the batteries over and over and plugged it in to the USB cord and it still will not turn on. A green light flashes once when 1st clicked on then a red light flashes like 2 times and it wont turn on. I dont know if its because i dropped it or if its just the batteries going dead or something!
    Problem Solver:
  • 6 Answers
I think tonid is right try to check your batteries first before going to kodak the is a possibility that your battery is the problem.That will save you some money.
If you are good in disassembling part check you cam for loose connection am repairing to the inside connection of you cam.
If you think your can't disassemble if and no idea it is better to go to the nearest kodak to fix it for you
Posted on Apr 03, 2009
    Problem Solver:
  • 5 Answers
When this camera is dropped you have to send it back to kodak so they can replace a part in the camera, it will cost $70.00.
Posted on Dec 03, 2007
Your batteries will proberbly dead. you should try changing them
Posted on Oct 17, 2007
SOURCE:
Dropped camera shutter doesn't work but video does
Did you remove the battery and replace it after a few moments? this will "reboot" the camera, like a cold boot from a computer. Then try again. I can't believe a landing on the carpet would cause mechanical problems, but you never know.
Could be just a setting, and that will be restored after the boot.
Aug 27, 2014 | Olympus Cameras
What if I don't have the USB cord for the camera??
If the cord fits, use it.
You didn't specify the make and model of your camera, but if it uses a memory card of some type you don't need a USB cord to transfer your pictures.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 19, 2013 | Cameras
Can I plug my Vivicam X027 into regular house electricity and use it plugged in?
Yes, but not easily. Since the camera is designed to be powered by three AAA batteries in series, you would need a battery eliminator that fits into the battery compartment.
The camera does NOT take power through the USB port.
Jul 18, 2012 | Cameras
My usb cord wont fit into my kodak easyshare z740
Consider NOT using the USB connection.
Jun 06, 2012 | Kodak EasyShare Z740 Digital Camera
Rec'd the wrong usb cord with camera, where can i BUY ANOTHER USB CORD TO FIT THIS ONE.
http://www.olympusamerica.com/cpg_section/cpg_support_accessories.asp?id=1397&ct=7
You might also want to consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Aug 19, 2010 | Olympus FE-370 Digital Camera
I plug in the camera cord into the computer (it is the right cord) and the camera just switches off
Try NOT connecting your camera to your computer.
Apr 22, 2010 | Samsung S860 Digital Camera
HELP!!!!!!!!!! USB cord needed!!!!
You don't need a USB cord.
May 31, 2009 | Vivitar ViviCam 5299 Digital Camera
My rim blackberry is switching off frequently and shows Device error:373 pls tell how to solve this problem
Try taking the battery out for about 10 minutes. Plug in the power cord only. Once it powers up with the power cord only then put in your battery. Unplug the power cord only after the battery is showing a full charge. Turn off the device and turn it back on.
If that doesn't work you can try dropping it on the ground a few times on a carpeted area. Make sure it drops on the face about 5 or 6 feet up. I know...I know...sounds crazy.
Otherwise, you can wipe it clean but that erases all data on it.
Apr 24, 2009 | RIM BlackBerry 7290
When I plug in the M407 camera nothing happens
Consider NOT connecting your camera to your computer.
Mar 15, 2009 | HP Photosmart M407 Digital Camera
Camera was dropped
This is probably a Technitians job, But you are VERY lucky that further damage was'nt done!
The Best advice is to get an SD card reader that the memory card can plug directly into and this will then plug via USB, and come up just like a USB stick. You'll probably find it is faster than the software too.
Jul 21, 2008 | Pentax Optio M20 Digital Camera
Kodak EasyShare C653 Digital Camera Logo
122 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
