Question about Staples Cross-Cut Shredders; 10 Sheet
Blue light with lighting bolt is on - Staples Cross-Cut Shredders; 10 Sheet
Where is crankshaft position sensor located on a 2006 dodge caravan 2.4
It will be on the back side of the engine (firewall side) in the block down by where the oil pan bolts up. Look towards the passenger side. It will have three wires. Pink with yellow. Brown with light blue. Dark blue with dark green.
Mar 01, 2015 | 2006 Dodge Caravan
My CyberPad iview's battery is completely dead. How do I recharge it? Blue light is not lit when it's plugged in and there is no lightening bolt appearing.
Is the charger ok?(silly me). Unless the battery is functionally dead, it should work. Sometime plugging into another wall outlet may help.
Jan 16, 2014 | Iview Cyberpad 900TPC 9-Inch Tablet
Flash goes every time, even when there is no lightning bolt in the screen (for lack of better terms). Also a few photos turn out blue that were taken indoors.
210 wide camera is auto detect the environment. If you face it under bright light, the flash will auto off, if away from bright light, it will auto have flash. for photo have blue hue do show me the image, i take a look
Jan 10, 2014 | FUJIFILM Instax 210 Film Camera
Can't remove stock from Rossi single shot
Remove the butt plate (should be 2 screws), shine a light down the stock bolt hole to determine if you need a socket and extension or a long screwdriver. Use the appropriate tool to remove the stock bolt. Righty tighty, lefty loosey.
Oct 02, 2013 | Rossi 308 Winchester Single Shot w/23 Blue...
Change light
i just put fluorescent lights in two of these fans. it just takes a little fabbing and its done and simple.
Go to home depot and buy a lithonia lighting 11" low profile round light model# FM22 ACLR LP.
tools:
drill
rotozip or file
wire strippers
crescent wrench
screwdriver(phillips)
you can take the neons and the power supply off of the fan base but be sure to save all the screws, you will need them later. the ballast in the light will fit in the chrome base on the fan but you have to shave one of the bolt holes down first for it to fit (be sure not to cut the ones that the bolts go through). you do not need the green ground wire from the new light.
Next drill out the rivets from the bulb brackets on the new light base. now you can take the bulb and place it on the fan backing plate and get your bulb brackets and mark where you will mount them. then drill holes for them (but make sure the holes are for the screws that you saved earlier because you will reuse them for the light brackets). Be sure to mount the bulb as center as possible.
now once you have fabbed everything put the assembly up to the fan and pull the wires down through the ballast and through the center tassle bolt and wire it up. the bulb is an 8" bulb and thats all that will fit. home depot sells phillips 8" bulbs in several different brightnesess.
this picture was taken on my phone so it isn't that great. but the light really brightens it up.
Oct 08, 2009 | Hampton Bay 37225 Cameron II Plus Fan
Electrical short
Tighten those four bolts making sure no wires are in the way or damaged where they come out of the cokumn right around the area of the column clap
May 29, 2009 | 1989 GMC Sierra
No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Staples Cross-Cut Shredders; 10 Sheet Logo
42 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
