E1 fault code on maytag a/c inverter 12,000 btu
SOURCE: Error code A5 on Frigidaire
I have a Frigidaire model FAK104R1V window air conditioner that did the same AS error code. The problem is going to be one of the 2 temperature sensors in the unit. Mine happened to be the ambient temperature sensor located at the front of the unit. They are fairly easy to replace and you can buy a new sensor for about $15 online.
Posted on Jun 05, 2009
  • 67 Answers
SOURCE: Just bought 12,000 BTU unit from Lowes. It worked
you have to balance the adjustment of fan speed and the amount of coolness you set the unit for. Either increase the fan speed or lower the coldness setting.
Posted on Jun 25, 2009
james3751
  • 614 Answers
SOURCE: Looking 4 a minisplit - heating & cooling - 12,000 btu 16-20 SEER
I have been doing this for 45 years and for the price the Amcor is the best because they send you everything you need to install unit. I just installed one for my neighbor18,000btus He paid 1000 included shipping. The tech support is great. Russ
Posted on Jul 26, 2009
  • 691 Answers
SOURCE: does 12,000 btu= 1 ton
yes 12,ooo btu= 1 ton , 24,ooo = 2 ton, 36,ooo = 3 ton
Posted on Sep 05, 2009
  • 3 Answers
SOURCE: DeLonghi A120 12,000 btu ar conditioner Leaks
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Posted on Jul 26, 2010
Looking for fault codes F-7, E-5 and F-5, E1
We don't know what brand you have, so Google (brand) washer fault codes F-7, E-5 and F-5, E1 As you indicate you have a Maytag, that means this search: https://www.google.com/webhp?hl=en#hl=en&q=maytag+fault+codes+ Those specific codes are a lid switch and Shifter actuator fault
May 14, 2016 | Washing Machines
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
F5
Hi, F5: Outdoor discharge sensor open or short circuit.
Sharp error codes
Air Conditioning Fault Codes
Mar 04, 2014 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
Error code F8 E1
My Maytag MVWX700XW1 washer does not spin, the lid lock light is flashing red and when I run the diagnostics, and check the Fault Error code I get F7 E1.
I would alos like to find the list of Fault Error codes.
Thank you for your help.
John
Jan 10, 2014 | Amana Washing Machines
What is the btu of this model.m7q08f2a.
Hi, to find out the tonnage of your unit in b. t. u.'s, look at the 08 in your model number. There are 12,000 btu's per ton of cooling. You have a window /wall unit, and according to the model # 08 is not a 1/2 ton or a 1 ton, but a 3/4 ton unit or 8,000 btu's if indeed this is the correct model number. Most units we come across are in btus as 06 which is 1/2 ton, 12,000 is 1 ton, 018 is 1 1/2 ton and on up with a properly matched indoor coil. Your unit is a package window unit, so both coils are equal.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Nov 18, 2010 | Maytag M7Q08F2ACOM Air Conditioner
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Heating & Cooling Logo
226 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
