Question about Maytag M6Q10F2A Air Conditioner
How can I find out what my Energy Star rating, Max Fuse/Breaker, min circuit amps and RLA of my Model # CH42ACD1V
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: i have a new microwave oven,model#MMV4203DW &
Chances are you have a failing high voltage transformer.
Often there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
See these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Here is a link you or someone you know can use for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/xformer.html
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Maytag owner's manuals and installation instructions here.
Posted on Dec 05, 2009
  • 2509 Answers
SOURCE: electric dryer trips circuit breaker after about 5
Most likely culprits are the thermostat (or a short in the wiring related to the thermostat) . I am assuming it is a normal current breaker and not an earth leakage breaker. It seems likely to be the thermostat as that probably switches after a few minutes (whereas the element which is also a common failure is on from the start of the cycle, so if there was short in the element that would take the breaker out immediately).
Does it do the same whatever heat setting you select?
If you switch it back on before letting it cool to much does it trip sooner?
If the time it takes to trip changes when you change the heat setting that would point to the thermostat/wiring too.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Posted on Feb 15, 2011
The wire in my house for an elec. garage heater is 14 gauge wire with a 15 amp breaker. I assume i need at least 10 gauge wire with 20 amp .The heater is 20.9 amps and 3000-5000 watts, with 17500 BTUs
Curt, a 20 amp breaker will blow if you pull 10.9 amps from it. I suggest having a licensed electrician do your wiring. Likely, you need a permit anyway.
Oct 22, 2015 | Water Heaters
My inside and outside unit turn on fine, out side fan and compressor running good,inside blowing cool air, about four minutes after that, out side unit shutoff, no humming, nothing.
Are you heating or cooling? When the outdoor unit shuts off how does it come back on. Or are you saying that the outdoor unit is short cycling off and on
Jan 17, 2018 | Ruud Heating & Cooling
I believe I might need to change my (20 amp) breaker switch that is running on 10-2 wire which supplies power to my Rheem Classic 10 Seer. I'm not sure if I need to have 220V of power on a 30amp...
Hello, the unit runs on 220 volts that's why # 10 wire must be used. The best bet is to use a 40amp breaker for 220 volts, gives the circuit more protection.
Sep 04, 2011 | Heating & Cooling
I have a ruud ubhc-14j11sfd will a 17500 50 amp generator run without any problems
Look at the data plate on the unit, You need the LRA locked rotor amps, and RLA run load amps
It will also show max fuse size and min fuse size. A 3-4 ton unit should run on the gen, but starting is my question, this can be 3-7 times run load amps.
Aug 31, 2011 | Ruud UBHC Air Conditioner
WHAT IS THE MAX AMP DRAW?
Max amp draw refers to the total amp draw of a unit , example : Compressor RLA 25 Amp, blower motor FLA 5 Amp, and condenser fan motor FLA is 1.5 amp , you add all three and get 31.5 Amps
which is your max amps, this is used in determining wire gauge and breaker size for unit.
This should help.
Jul 27, 2011 | Heating & Cooling
We need query regarding new installation of 6.6KV circuit Breaker. can u give me phone number or address of concern person or dealer or siemens customer care
Hi, please find it at below : http://www.energy.siemens.com/hq/en/business-portal/
For more information please contact our Customer Support Center:
Phone: +49 (0)180 524 70 00
Fax: +49 (0)180 524 24 71
(Charges depending on provider)
(From the German fixed network € 0.14/min.
and from the German mobile phone networks
max. € 0.42/min.)
Siemens AG
Energy Sector
Freyeslebenstrasse 1
91058 Erlangen
Germany
Jan 20, 2011 | Siemens 200 Amp Main Breaker 30 Spaces 40...
I have a wood planer with a 3HP 220 single phase motor wired to 20amp circuit breaker in my house. I usually run the planer off a 12gauge extention wire about 30ft from the house plug. I would like to...
Look on the planer to see what the R.L.A. are, for example 16.0 amps. Set a box with 2- 20 amp fuses, or a double pole 20 amp breaker. Do not exceed the amperage of what the planer says on its data plate. If the R.L.A. is 10.0 to 19.3, use a 20 amp.
Sincerely,
Shastalaker7
Jan 20, 2011 | Inline 20 amp. In-Line Circuit Breaker
What size of circuit breaker to use?
take the cover off of the front of the unit theres going to b a model serial tag i need the RLA or max amp draw to answer this question
Apr 06, 2010 | Whirlpool ACQ108XL Air Conditioner
I need the full load amp rating of the Trane YHC063A. I have the minimum circuit ampacity, the max fuse and the max circuit breaker already
Look on the rating plate on the unit itself - look for something labled as FLA. If you don't have access to the condensing unit, go to WWW.TRANE.COM and search for your full model number.
Sep 09, 2009 | Heating & Cooling
Pioneer 12v car amp rated at 1200 watts max requires ? amp fuse
Hi I would suggest 40A (i know guys will disagree) but you shouldnt be running at full 50A. Fuse are often rate at 50% - 75% of the actual consumption. By the way, 8 guage @40A will give you about a 2% drop at 5 feet. Maybe consider heavier for 40A?? Just a suggestion
Jul 24, 2009 | Audio Players & Recorders
Maytag M6Q10F2A Air Conditioner Logo
21 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
