ELEFW327 flashes on and off repeatedly only after power is switched on
  • freshfix Nov 21, 2013
    It is an element electronics product television
    It is an element electronics product television not solution just adding on to my question
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Posted on Nov 21, 2013
Testimonial: "it will be red for standby then when i turn the power on the light turns green and stays green until the units turns off and it turns back to red for standby and will do this continuously until i unplug it from the outlet"
2002 f150 cruise inop shows code 3?
  • 3 flashes - deactivator switch is open or circuit defective.
    • Flash code 3 - deactivator switch circuit failure
    • Central junction box (CJB) fuse 13 (20A).
    • Circuitry.
    • Deactivator switch.
    • Speed control servo.
    • Go To Pinpoint Test H .
    PINPOINT TEST H: FLASH CODE 3 - DEACTIVATOR SWITCH CIRCUIT FAILURE
  • CONDITIONS DETAILS/RESULTS/ACTIONS H1 CHECK THE DEACTIVATOR SWITCH CIRCUITRY
    Speed Control Servo C122
    Measure the voltage between the speed control servo C122 pin 9, circuit 307 (BK/YE), harness side and the speed control servo C122 pin 10, circuit 57 (BK), harness side.
    • Is the voltage greater than 10 volts?
    Yes INSTALL a new speed control servo. REFER to Speed Control Servo in this section. REPEAT the self-test.
    No GO to H2 . H2 CHECK DEACTIVATOR SWITCH POWER
    Deactivator Switch C1025
    Measure the voltage between the deactivator switch C1025, circuit 10 (LG/RD), harness side and ground.
    Yes GO to H3 .
    No REPAIR the circuit. REPEAT the self-test. H3 CHECK CIRCUIT 307 (BK/YE) FOR AN OPEN Measure the resistance between the speed control servo C122 pin 9, circuit 307 (BK/YE), harness side and the deactivator switch C1025, circuit 307 (BK/YE), harness side.
    • Is the resistance less than 5 ohms?
    Yes INSTALL a new deactivator switch. REFER to Speed Control Deactivator Switch in this section. REPEAT the self-test.
Nov 23, 2016 | 2002 Ford F-150
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
Constant flashing red light near on/off switch
i think it is the power supply board problem
Nov 05, 2013 | Televison & Video
My camera is flashing E:91:01 and with what looks like the flash symbol flashing- my flash does not work when taking pictures though, its all dark. It does this on all settings. What does E:91:01 mean and...
This seems to be a common problem with several Sony camera models.
Various solutions are offered on different websites and may be worth trying.
Solution A.
1. Remove battery
2. Press and hold power switch to 30 seconds
3. Replace battery but DO NOT switch on for at least one minute
4. Switch on the power.
5. See if the problem is fixed.
Solution B.
1. Open the MENU and find SETUP
2. Repeat INITIALIZation process
3. If this fails then repeat steps 1 & 2 but then turn off the flash function very quickly after step 2.
This may fix the problem although it means you can't use flash.
Solution C.
Some Sony camera models have a RESET button either under the LCD cover or under the memory card cover and pressing this button may fix the problem.
Jul 27, 2011 | Sony Cameras
Tv shuts off after 10-20 minutes
its not the problem with ur electron gun tube or with any picture ic or sound ic. Every t.v. is microcontoller switched machine.
any damage to microcontroller ic that controls the switching will lead to this kind of problem.
0.01% chance of residue EHT voltage would have affected the microcontroller.
Jun 06, 2009 | Panasonic TH-42PC77U TV
Lights flash when opening power doors
when you open the power sliding doors the turn signal lights are supposed to flash. are there other lights that flash?
Dec 29, 2008 | 2005 Dodge Caravan
Whirpool cabrio top load washer 1.5yrs old flashes FXX error code
Try this:
  1. Switch off the power using the 'MAINS ON/OFF' button
  2. Press and hold the 'Temperature' button
  3. Carry out the next three steps within 3 seconds;
  5. Release the 'Temperature' button
  6. Press the 'Soil type' button
  7. Check that a message similar to "DIAGNOSTIC MODE 123F7F2F5V127" is displayed. If it is not, repeat from the beginning
  8. Switch off the power
  9. Switch on the power. The fault code should have cleared.
Dec 10, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Televison & Video Logo
Top Televison & Video Experts
