Question about Promise Controller Card Fasttrak TX4660 4PORT SATA/SAS PCI-EX4 RAID HBA Retai
Tx4660 rebuild when does a rebuild occur with a tx4660 promise fast track, when entering the card bios or in windows?
2 Suggested Answers
SteveRand
  • 210 Answers
SOURCE: Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Posted on Aug 20, 2008
I'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Aug 26, 2011 | Toshiba Computers & Internet
Bios speed slow fast karni hai
First of all, your computer must be completely powered down and turned off before starting this process. You won't be able to edit the BIOS in sleep mode or hybernation mode. Next, power on the PC and enter the system BIOS. How you enter the system BIOS screen will vary according to your computer's manufacturer. This usually involves a series of keystrokes. Which keys are used will depend on your system. Now that we are in the BIOS screen, we are ready to speed up Windows XP boot time. Find the Boot menu and select it using the arrow, Tab and Enter keys on your keyboard.In most systems, you'll find a Quick Boot option. Enabling this will skip common system self tests that occur automatically when the computer is powered up.
In the next step to speed up boot time, look for the Boot Device Priority option. You should change the first boot device to your hard drive. This will speed up boot time, but won't allow you to boot via a boot disk like CD or floppy. If you make this change, then need to boot from a disk later, you can re enter BIOS and change it back. Next, choose the option Exit and Save Changes and the computer will restart.
Always Remeber to do this process carefully because a wrong action will cause destruction and make your computer useless.
Dec 04, 2010 | IBM ThinkCentre 8172 Intel Desktop PC -...
While instaaling fast track pro i get a msg that your computer's operating system is not supported for the use of fast track pro at this time
it requires a higher standard operating systems to install this software... if you are running in windows Xp try upgrading to vista and install the software... if you are already running in vista or win7 then it says that it requires a 64 bit operating system.....
Aug 04, 2010 | M-Audio Fast Track Pro External Sound...
What is the video memory of a Compaq Presario SR5712F PC Desktop
Description---- Problems with video cards show up as intermittent system lockups when playing 3D games, small dots of color spattered across the Window desktop, the inability to run certain 3D games, and the inability to open Windows normally. All of these issues can occur because of video hardware or driver problems. Find an item below that matches your video need: For integrated video memory that is adjustable, use the following steps to change the amount of video memory (RAM) from the PC BIOS Setup:
  1. Turn on the PC.
  2. When the blue HP screen appears, press the F1 key. Entering Setup should appear on the screen.
  3. When BIOS Setup screen appears, use the RIGHT ARROW key to select the Advanced screen.
  4. Use the down Arrow key to select the video memory setting; for example; VGA RAM Size, integrated video, or On-Board Video Memory.
  5. Press the Enter key.
  6. Use the down Arrow key to select the desired amount of memory or memory setting that is listed and then press the Enter key. CAUTION: Do not select a DISABLED setting without a video card installed! Doing so can cause the monitor to go black until a video card is added or the BIOS is reset.
  7. Press the F10 key, and then press Enter to save changes and exit. The PC is set to use the new video memory setting.
tell me if this was helpful
Apr 26, 2010 | Compaq Presario SR5712F PC Desktop
NTLDR is missing
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini
So, verify whether the BIOS is up to date.
In this case, it's required to reinstall the Operating System as repairing this part may be a really tidious job.
Oct 18, 2009 | Acer Aspire One AOA150-1786 Notebook
Emachine T2385 Won't Boot in Normal Mode past Windows XP Screen
The first thing I would check is your video card (usually driver) problem. Start windows in safemode with networking. If this problem has occured after updating the video card driver you may try rolling back the driver to a previous version, otherwise try
Once windows starts you'll want to go to the start menu and find and click run. In the text box enter the command "devmgmt.msc" and hit enter and the device manager should appear. Look for display adapters and left click the + and you should see your video card. Right click the video card and select properties from the drop down menu. Select thr driver tab. Now if the problem had occured after updating the driver, choose rollback the driver from the menu. If not try selecting the update driver option. After updating/rolling back the driver you'll want to try restarting in normal mode.
If it still won't start in normal mode you can try troubleshooting the video card under the general tab in properties, though to be honest I've found this rarely usefull but it might help you. Otherwise you'll want to make sure that your videocard is enabled in BIOS. A quick totorial of BIOS if needed http://www.tomshardware.com/reviews/bios-beginners,1126.html.
Otherwise it's likely a physical issue with the graphics card. Since you've tried reseating the card already it may be that the card is damaged and will need to be replaced.
Aug 08, 2009 | E-Machines Celeron 2.3GHz (rb-t2385)
Boot up cycles, windows appears, but reverts back to boot
It may just be a default setting in the new BIOS. Enter the BIOS setup and check the SATA mode - I've seen this occur with the ACHI mode for example. Otherwise you could try Safe Mode and see if you can get into Windows at all. You can also press F8 while booting and select the option to Disable Automatic Reboot so that you can see the Error that is occuring for further diagnosis.
Feb 14, 2009 | Acer Aspire 9300 Notebook
Aug 09, 2008 | Promise Ultra133 TX2 ATA Controller
K8T Neo Motherboard with Via and Promise SATA problems
http://www.versiontracker.com/dyn/moreinfo/win/140882
the above site has driver via Hyperion pro 11.5mb
http://www.soft32.com/download_170761.html
This one has promise fast trak driver
Hope this helps please post rating thanks
Aug 01, 2008 | MSI K8T Neo-FSR Motherboard
Promise Controller Card Fasttrak TX4660 4PORT SATA/SAS PCI-EX4 RAID HBA Retai Logo
47 people viewed this question
Top Promise Computers & Internet Experts
none
Bill Boyd
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
