Question about Miele S548 Bagged Canister Vacuum
How do I unplug my Miele S548 vacuum?
I already changed the bag, but the red bar still shows half-way.
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
  • 195 Answers
SOURCE: Reset light is on.
set big Cat to stay on porch. (Smile)
Posted on Dec 07, 2008
ukvacfan
  • 328 Answers
SOURCE: Miele Mistral S7280 won't run after changing the bag
The Mistral range is the same as the new S7 that's just hit Europe. Have you made sure that when you turn on the vac on the handle that you've switched the carpet mode on? There's a separate button just under the power on button that activates the Carpet setting. Other than that check the sole plate where the roller brush to check for a blockage.
Posted on Jan 23, 2009
tooltech75
  • 80 Answers
SOURCE: Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Posted on Oct 07, 2009
VacuumRepair
  • 438 Answers
SOURCE: Miele Champagne Vacuum Cleaner Model S548
Greetings from ,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum cleaner. 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine.
Ok, so you need to replace the cord reel on a Miele , no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to your Miele Champagne. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
Posted on Mar 21, 2010
Bounced down a step while on, blew house circuit breaker, now s548 only powers on when on its side
Rickhan,
I would recommend taking it to a Miele dealer and let them repair it. It can get rather tricky trying to put those back together. I speak from experience and I work at a Miele dealer and I leave them for the other repair tech.
Jul 04, 2015 | Miele S548 Bagged Canister Vacuum
Power is on but no suction....
I recommend taking your vacuum to a qualified repair person for diagnosis and/ or repairs. Electronic repairs can be fairly reasonable to fix but much more expensive and dangerous if not done properly
Apr 21, 2014 | Miele S548 Bagged Canister Vacuum
My Miele S548 does not turn on. I am suspecting power cord contact inside. I am pretty good at disassembling electrical equipments including TVs and laptops. Not being able to open the vacumm canister...
heya,
your exactly right. there is probably 2 or 3 screws your missing there.
now getting to these screws is easy. If you haven't already, remove the top filter and the bag door lid.
Assuming you have taken the screw out holding the black control panel out already... you want to remove the black panel with your on/off switch and the cord rewind. Once you have the panel off there are a couple of screws there that are holding you back. once removed, you should have full access to the underneath with the motor and cord rewinder there.
Good luck,
Mark
Nov 11, 2010 | Miele S548 Bagged Canister Vacuum
Miele canister keeps shutting off when i press + it starts again for short while and off again whats problem i have changed bar but still no good
Was it hot when you pressed "+" button? Did you check the filters(Hepa) or bag if clogged or suction path was blocked? Does it happen after it was cool down? From what you said, it seems none of the above. Only thing I can think of is circuit board. The mortor runs in variable speed. "+" increase the average voltage to the motor thus higher suction. PWM circuit in main pcb may not working correctly.
High priced vacuum cleaner like this shouldn't fail like this but it does. JMO.
Nov 07, 2010 | Miele S548 Bagged Canister Vacuum
Outside of canister is dirty and has scuff marks.
there is a product called Vac Polish. I use it to clean all our repairs in my store and for my Miele Champain S548. Im not sure where you can get it, I Order it from my supplier and ill be happy to ship you a bottle if you would like. My email is chuck@acevacuums.com
Apr 08, 2010 | Miele S548 Bagged Canister Vacuum
Have a miele S546 vac. and it won't turn on. Is there a fuse? Can the on/off switch burn out? Thanks.
If you vacuum wont turn on it is most likely the cord winder. This is a pretty big repair, you wouldn't want to attempt it yourself. Most shops should be able to repair the cord winder for about $50-75. If you need a new cord winder expect to pay about $150.
Oct 13, 2009 | Miele S548 Bagged Canister Vacuum
Miele S548 Bagged Canister Vacuum Logo
35 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
