Question about RCA RP7887 High-Performance Super Radio
AM reception/AM power problems
I bought this radio a couple weeks ago to listen to talk-radio while at work. The AM reception in the building I work in is fine on other radios I've tried. I bought the Superadio in hopes that I could get even better AM reception. Unfortunately, I am getting worse reception on most stations I listen to and no reception at all on others. While on "wide-band" setting I get no stations lower on the dial than about 1200 (though occassionally, if I turn the radio around and spend a lot of time tuning it, I sometimes can pick up a station or two for a few minutes, then they go away almost as if the radio is losing power). Using "normal band," I can only get a few stations on the entire dial (but too much static to be enjoyed). FM seems to work alright -- but I haven't messed with it a lot. I've tried an external antenna (albeit, a cheap indoor one), and it makes no difference at all. Is there anything I can do to fix this? Can I open it up, make a few wire adjustments and get better am reception, or should I just return it?
  • millikin Oct 24, 2007
    Hey "Guest,"
    I think you're missing the point of this website.
    Thanks for the important life lessons about work, recreation and residential reception though.
    To your concerns:  I have a job where I can listen to the radio without it interfering with my work. The office isn't in a concrete-industrial shell.  If you had actually read my original post -- you'd see I made it clear that bad reception in this building isn't the issue.
    For people actually interested in fixing the problem with the RCA Superadio:  I opened the radio, reversed the speaker leads, closed it back up and now it works great.  For info on how to do this, check here>> http://mysite.verizon.net/vze20h45/radio...
    New Friend:
A portable Loopstick tuning antenna is probably the BEST option. Also, the quality of the portable radio you are using is vital since the internal ferrite loop antenna is the single most important factor when attempting to use electromagnetic coupling for better radio reception on the AM (Medium Wave) band. That being said, the obstacle of a metal building's 'signal-shielding' may make it impossible to receive inside some areas of the structure. {Mark • KC9TSR}
Posted on Aug 14, 2016
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Posted on Oct 22, 2007
SOURCE:
I get great sound on my lg dare calls but the reception is poor. Sometimes caller on other end cuts out. Is the a way to get better reception. Current carrier is Verizon.
Your problem isn't your service provider-its your phone! I have a different LG phone than you, but from my own experience and what i have heard from many people who have LG phones, they all have reception problems. LG phones have terrible antennas in their phones. I'm trying to work on a solution to that now, if its possible. Contact me(True Love in DC) in a week to see if i discovered any solutions. In the meantime, a good thing to know about reception with ANY phone is this: the antenna is always at the top of your phone. Avoid holding or placing your hand and fingers near the top of your phone. And NEVER bend over while talking on the phone as u will be pointing your phone towards the ground. This almost ALWAYS cuts off your reception or even disconnects your call in progress. Learn the best reception spots in and around your home and other places you may be at too. Avoid walking around while talking on the phone. Certain buildings or parts of buildings play a part in your reception as well as certain lighting in the building. And finally, atmospheric conditions(storms, cloud cover, etc) are a big contributer in reception problems!
Jul 20, 2011 | Lands Phones
I have a new Onkyo TX-SR508 receiver. When listening to FM radio the audio cuts out repeatedly for anything from a few seconds to a minute. Power fluctuation is very unlikely to be the problem. Signal...
Does the display show "tuned" or "FM Stereo"? This would normally indicate a good reception. The tuner has a signal level threshold and if the signal gets to week, the receiver mutes to prevent noise in the speakers. Swithing to mono make reception less intolerant. Does the problem also occur, when you switch to mono?
Jul 14, 2010 | Onkyo Audio Players & Recorders
Merc C200 - Problem with aerial?
try takeing back out and see if the conection on the back has come off if not have a look at the conection its self
Mar 29, 2010 | 2000 Mercedes-Benz C-Class
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
Cannot communicate on radio
You almost certainly have a bad antenna connection. Try re-soldering the PL259 connector. Do not transmit until you have at least got weather reception.
Jan 13, 2010 | Boating
Tuner does not work
If you're trying to listen to FM, and are indoors, and your walls are fairly thick, or brick and mortar, chances are you're not getting a strong enough signal.
Modern minisystems like yours come without an external antenna, and use their power cords in lieu of one. Try extending the cord, not coiling it, for better reception.
Other than that, your system may have had a spontaneous problem to its FM tuning module, though not likely.
Aug 29, 2009 | RCA RS2664 Shelf System
No radio reception in office.
most portables have a very weak FM receiver, and a building interior tends to block a good deal of signals. your best bet is an old fashioned unit with a large retractable antenna.
Jun 12, 2009 | RCA RP7887 High-Performance Super Radio
Radio reception problem
keep the antenna away from the metal contact.
Jan 01, 2009 | RCA RP7887 High-Performance Super Radio
RCA RP7887 High-Performance Super Radio Logo
1,208 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
