Question about White Sewing W3300 Computerized Sewing Machine
The upper thread isn't grabbing the bobbin tajima machine
SOURCE: bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Posted on Sep 06, 2008
  • 360 Answers
SOURCE: Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Posted on Feb 08, 2009
louislevel_2
  • 374 Answers
SOURCE: Threading bobbin on White sewing machine
hi!
trouble threading well! particularly this not the same on your actual machine but same process is made just watch how does it work and surely you have solve your problem and learn something new.on internet explorer type the address www.youtube.com then on you tube search type "sewing machine" then there a lot of shown for threading and more.enjoy watching while you learn.have a nice day and don't forget to rate me,thank's
Posted on Apr 09, 2009
  • 47 Answers
SOURCE: How to Thread the bobbin on my sewing machine
Visit us at www.ifixmachine.com to avail for a new manual for only $10.00
Posted on Jul 24, 2009
  • 1116 Answers
SOURCE: I have a WHITE 3300 EMBROIDERY MACHINE and the
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Posted on Mar 18, 2010
How to fill the bobbin with thread
The bobbin is a little metal wheel that is usually housed under a plate where the upper needle darts down into. Slide the plate aside and fish the bobbin out. Put the bobbin up on the upper right hand side of the sewing machine and connect thread from the full spool of thread to the bobbin and then when you push the pedal down, (if you have arranged it right), your machine will automatically fill the bobbin with thread and automatically shut off when it is full. Then you have to leave a bit of thread hanging out when you put the full bobbin back down into its hiding space. Of course, you can always fill the bobbin by hand too. When you put it back in its housing, some thread has to be hanging out as the needle will drop down, grab it and the two threads (the top one from the needle, and the bottom one from the bobbin) work together.
Machines work differently but the is the main idea behind most of them. I hope that helps.
Feb 08, 2015 | Sewing Machines
Install bobbin in euro-pro X 464XC
Either your machine was not threaded with the presser foot wasn't up when you threaded the upper thread... or your upper tension isn't tight enough.
Good luck.
Sep 14, 2012 | Euro-Pro Fast and Easy 420 Mechanical...
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
BOTTOM THREAD WONT CATCH
are you sure you have the bobbin in correctly? I mean most machines require that the bobbin un-spool in a specific direction to work properly. Also make sure your needle isn't damaged or bent and is inserted fully into the needle bar.
Good luck
Jul 29, 2012 | Sewing Machines
It stopped picking up the bobbin thread while sewing. In the middle of a zig zag sewing project, it stopped picking up the bobbin thread. I cleaned the bobbin area and needle area and tried again and it...
You can take the slide plate off, that your needle goes through and watch to see if the arm grabs the bobbin thread, if you can get it to pick up, than slide scissors or something flat under your needle and manually pull both threads through, replace the plate.
Your bobbin thread could be wound to tight or spliced threads on it, and your tension needs to be adjusted. If your using a pedal, try setting to a slower speed.
I would try a different bobbin and thread it manually as in the step I mentioned, if you can't see the arm grabbing it, you will need to check to see if you have loose threading jammed in youir machine, if this isn't the case and adjusting the tension dosen't help...than you will need to replace the bobbin casing.
Kind regards!
Sep 12, 2011 | Janome 2049LX Mechanical Sewing Machine
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
The bobbin thread is not catching. I have rethreaded the entire machine multiple times, tried different bobbins, etc. However, the needle and thread are not catching the bobbin thread. The bobbin thread is...
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Aug 01, 2010 | Brother Disney PE-180D Computerized Sewing...
My machine wont pick up the bobbin thread, and when it does, and I start sewing, it keeps jamming, and the thread locks around the bobbin spindle. It keeps sewing in one spot, which I have to cut the...
check that the bobbin thread is pulled thru 'the tongue' of the bobbin case: that is what controls general tension of the lower thread. also make sure the upper thread is threaded thru the tension disk and the disk is 'grabbing it'.
Feb 02, 2010 | Sewing Machines
Can't draw up the bobbin thread on my Brother LS-1217 sewing machine... it just won't catch
Make sure you have enough of a "tail" from teh bobbin... Probably 4 inches or so before starting. If that doesn't work, check upper tension and needle is properly seated.
The needle drags the thread down and then starts back up causing a loop at the eye which a shuttle goes through and acrries the upper thread over the bobbin. The upper thread then drags the bobbing thread up.
Sep 13, 2009 | Brother LS-1217 Mechanical Sewing Machine
Needle doesnt hook bobbin thread while sewing
Our machine had the same problem, there was a piece of broken thread stuck in the upper tension spring keeping the tension spring open. removing the broken thread in the upper tension solved the problem for us
Feb 20, 2007 | Simplicity SE3 Computerized Sewing Machine
White Sewing W3300 Computerized Sewing Machine Logo
126 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
