Question about Black & Decker Leaf Hog Blower Bv4000
NO POWER STOP RUNNING ELECTRIC '
Electric dryer motor keeps running after power off
If you mean that after the timer goes to the OFF position (or stop on some), i think it is a timer issue. They are expensive (over 75 bucks) so make sure that is what it is first. I am a do it yourselfer and not a pro. Just work on my stuff. The motor should stop after the timer goes to stop or off. If not the timer then there is a bad problem somewhere else meaning there may be a short. Try using another setting and see if it stops there. It should. hope this helps..
Oct 07, 2014 | Kenmore 7.3 cu. ft. Electric Dryer -...
Minta touch always running water (dont stop)
You probably need new electric valve. Check to see if you have power to the valve. You can take valve out and try to clean it
Sep 20, 2014 | Water Heaters
How to stop my water heater from running
Check for water leak.
Turn off all taps and put ear against pipe
Make sure toilet or outside faucet are not connected to hot line.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Aug 29, 2014 | Water Heaters
Rest button on electric water heater
Do not turn power ON before tank is full of water or element will burn out
Electric water heater heats 21 gallons water per hour
Gene
Aug 17, 2014 | Water Heaters
Starting problem
the blades stop when there isnt enough power to engage electric clutch sounds like a charging issue when the engine is running place a voltmeter to the battery there should be over 13 volts if not replace voltage regulator if that doesnt work replace stator
Jul 19, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My incoming voltage is only reading 200v, will this stop the unit from running??
If it needs 208 or 220 then yes it will stop the unit from running.Check the voltage at the circut breaker to verify its not a wiring issue.
You may need to get a new circut breaker.Also check a 115 volt outlet if its is also reading low ,like 100 or 105 volts then the power ccompany is cutting power back and theres nothing you can do.
Jul 20, 2011 | Dayton (3UG73) Electric Utility Heater
I have a mobile home with Intertherm electric furnace model FEH-015HA. It will not stop running whenever it has power. We have to switch off the circuit breaker to stop it. The thermostat has been replaced...
You could possibly have a bad sequencer. Turn off the power and check the normally open connections with an ohmmeter. If they are not open then it is bad.
Dec 20, 2010 | Heating & Cooling
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
Jul 09, 2010 | Electric Mobility Mobility Electric Power...
The electric Starter motor will not stop running
If the starter continues to spin after the engine is started..replace the key switch, it is bad
Apr 10, 2009 | Garden
Black & Decker Leaf Hog Blower Bv4000 Logo
42 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
