Question about SharpVision XV-Z1U Multimedia Projector
Blue dot in upper center of sceen
Unit displays a blue halo when projectig a black image
  • 2,239 Answers
There is a burn spot on the light filter on the blue lcd. you can call a sharp service center to purchase the part, but it's extremely involved to replace.
Posted on Aug 03, 2009
SOURCE:
Blue dots on black images
I can tell you that I had my plasma screen replaced in the 4th year. The tech told me that the replacement panel was much more reliable. You may be looking at replacing the plasma panel...(which may be more expensive than replacing the whole unit??).
Jan 29, 2013 | Samsung HP-S4253 42-Inch Plasma HDTV
I get red dots in the black areas during dark sceens
http://www.retrevo.com/support/Maxent-MX-42HPM20-TVs-manual/id/278ag118/t/2/
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
www.scribd.com/.../SONY-KDL42XBR950-TV-Plasma-Training-Manual
Use these links, user manual and two training manuals, these should help you isolate your problem
May 21, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
Screen turns black with white dots when i turn on my xbox 360
unplug all cords and reconnect them firmly should fix problem
Aug 05, 2009 | Microsoft Xbox 360 Console
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Blue dots and blue color
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Jan 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Open Questions:
See all SharpVision XV-Z1U Multimedia Projector Questions
SharpVision XV-Z1U Multimedia Projector Logo
205 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
