Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
How do I work wdbaaf0020hbk-01
I want to back up my computer
I have a WD 2 terabyte external hardrive, my computers will not recognize it, the lights in the front come on an dstay on, not blinking though. When i plugged it in i did see an arch inside the unit, i am...
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Aug 03, 2011 | Western Digital My Book Essential 1TB...
My wife, after I caught her cheating on me decided to delete or format my "My Book Essential Edition 2 TB Hard Drive ( WDBAAF0020HBK)" The problem I now have is that my PC doesn't even recognise...
try a new cord then check if you system sees it through your computer .dose your system have a restore point on drive try that let me know jim then we will see what else i can do for you.
Apr 05, 2011 | Western Digital My Book Essential Edition...
I have a Western Digital My Book Essential 2TB External Hard Drive. Recently My aunt knocked the unit over and since then it doesn't shown in my computer and the light doesn't shut off unless I in plug it....
Those unit have a regular hard drive in side maybe a plug has come loose inside take it back and have it looked at. Tech's can get the info off it for you.
Feb 24, 2011 | Western Digital My Book Essential...
Connecting gateway sx2800-01 to printer
This printer should be USB, so any USB port should work. Check with Dell to see if they have proper drivers (Windows 7) for your printer, and install them.
Nov 20, 2009 | Gateway Computers & Internet
42fd9925/01 screen not turning on
does unplugging it for 5 mins and plugging it back in help?
i'd call philips support, might have to get it repaired.
Jul 14, 2009 | Philips 170S5FB 17" LCD Monitor
CAN Y HELP ;) NEED CODES FOR THE BOX SUPER,ANY TIPS?
Hi, you could try, menu, 1570, ok on nagravision, and enter codes manualy, store them, and make sure emu is on.
C & W 5C 01] 07/05/09
00 = A7 B2 EE 5F 9D D8 69 0E
01 = 3D 82 E6 58 8E 0D B3 62
Telewest 5A 01] 07/05/09
00 = AA B7 D1 D9 CE 8E 83 AF
01 = 8E 80 D7 EF 44 93 02 2B
NTL 54 01] 07/05/09
00 = 5C 2C 26 36 CF 81 AB 66
01 = 2C 10 35 AC 06 57 BE 6F
Jul 12, 2009 | StarTech.com StarView SV211K 2-port KVM...
Ntl codes
Try these:
C/W 5c-01 May 7th 2009
key 00 = A7 B2 EE 5F 9D D8 69 0E
key 01 = 3D 82 E6 58 8E 0D B3 62
T/W 5a-01 May 7th 2009
key 00 = AA B7 D1 D9 CE 8E 83 AF
key 01 = 8E 80 D7 EF 44 93 02 2B
PURE (UK) NTL 54-01 May 7th 2009
key 00 = 5C 2C 26 36 CF 81 AB 66
key 01 = 2C 10 35 AC 06 57 BE 6F
IRELAND NTL 54-01
KEY 00 =B0 B8 4F 04 E6 5F 87 80
KEY 01 =A3 EB EC 07 D6 49 D2 EB
IRELAND CHORUS 5E-01
KEY 00 =CE 19 2E 87 80 61 74 90
KEY 01 =62 FA D9 F3 CE 05 FA 79
May 11, 2009 | Intel CPU
Starview Codes T.W. 16/01/09
C & W 5C 01 09/01/09
00= 7D 9B 0E 8B 69 3F E7 34
01= EF 38 DF 11 3D 85 FE 2F
Telewest 5A 01] 23/12/08
00= E7 D3 69 2E 6F 38 EA 78
01= E8 C9 E5 6E B0 49 53 F5
NTL 54 01] 09/01/09
00= 2E E9 B1 3F F7 F8 53 B2
01= 97 9B 22 E0 5B 13 B1 C7
Jan 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
What kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Jul 23, 2008 | Tascam DP01 All-In-One Recording Package...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
37 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
