Question about Dryers
How to reset for whirlpool dryer azb 6370 - Dryers
1. Rotate main button downwards (6 hour)
2. Push start 3 times
3. Rotate main button clockwise 1 position (7 hour)
4. Push start 3 times
Posted on Jan 01, 2015
2 Suggested Answers
  • 16 Answers
SOURCE: In what year was this product initially
it was manufacted/launched on date 03/04/2011
Posted on Oct 11, 2013
Have a whirlpool cabrio dryer model number WED8500DW1 the screen just flashed very fast like the touch screen is broken is there a way to reset the dryer
You can download the manual for your dryer at the website below. It's 40 pages. It may contain reset instructions, I don't know.
Whirlpool WED8500DW Manual
Nov 17, 2016 | Whirlpool Dryers
How do i reset the fault code FO4 on whirlpool dryer AZB 7570.i read the manual and it says i need to call service engineer
It can only be reset after fixing the issue with the unit. Have you successfully completed the repair?
Dec 28, 2014 | Whirlpool AZB 7570 White Electric Dryer...
Why is there no power getting to my tumble drier, what could be the problem?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Aug 10, 2014 | Whirlpool Dryers
I have a whirlpool azb 9750 and seems to have no pore but the fuse in the plug an the socket power is all ok, is there an internal fuse or thermal reset within the dryer
There are some overload/temperature switches within the dryer. Most reset when the overload/temp gone. You could open up the back and follow the wires to the overload switches and check with an electrical tester to see if you have power passing through each. The wiring diagram should be inside the dryer, and show each switch.
Jan 26, 2014 | Whirlpool Dryers
Azb 9750
If the motor doesn't turn then the bearings have dried up and it seized. As this point the start winding likely overheated and it would blow a thermal cutoff inside the motor as well. Replace the motor.
Nov 25, 2013 | Whirlpool Dryers
I have a nokia 6370, but the but is in german language...how can i change the language???
Einstellungen-> Telefon-Einstellungen-> Spracheinstellungen-> open it and select ur preferred language.
use this link for translation :
http://translate.google.co.in/?hl=en&tab=wT
Dec 23, 2010 | Nokia 6370
No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
273 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
