Question about Dayton Permanent Split Capacitor Motor Fan
Wiring diagram for century a/x motor model -sp-65l-bn4-202d
Amps = 5.4 volts = 115v h.p. = 1/3 rd
2 Suggested Answers
  • 5089 Answers
SOURCE: 115v electrical hookup for dayton motor 1TMY6
Dayton manufacturing is owned by WW Grainger
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1TMY6&op=search&Ntt=1TMY6&N=0&GlobalSearch=true&sst=subset
Contact Grainger 1-800-323-0600
They will have wiring information for each of their products.
The wiring diagram should appear on side of unit.
This 1.5 Hp motor can be wired for 115 or 230 volts
My AO Smith manual would not be specific to your motor.
With AO Smith 115-230V, there are one set of wiring terminals for incoming wires from breaker box. The other wires connect to terminals.
Copy following illustration link:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Wire and breaker size:
For 120Volt, use 20 amp breaker and 12 gauge wire up to 25 feet.
Over 25 feet up to 100 feet, use 30 amp breaker and 10 gauge wire.
100-150 feet use 8 gauge wire and 40 amp breaker.
150-200 feet use 6 gauge wire and 50 Amp breaker.
Posted on Sep 29, 2012
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
A.o. smith f48g56a76 wiring diagram
loo kon side of motor for 115 volt wiring they normally come wired for 220 volt
Dec 02, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
Wiring diagram 3/4 hp boat lift motor
It will be dependent upon the line voltage and switching mechanism...
Please advise drum switch or relays?
115V or 230V
Remote control present?
If a drum switch, is it a 6 or 12 terminal model or some other configuration?
Make and model of the switch?
There may be more questions depending on the answers to these...do you have a wiring diagram for the control? Are you replacing a motor and have the old and new motor schematics?
John
Apr 10, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
"You don't need to change the auger motor you do
Hi and welcome to FixYa, I am Kelly
Download this manual and go to page 36 & 37 for testing steps and wiring diagram. NOTE the voltages will be 115V DC and ONE voltage that is 115V AC the freezer door switch must be taped in the closed position to get any power.
Pin 1 = 115VDC
Pin 2 = 115VDC
Pin 3 = 115 V AC / L1
Pin 4 not used
Pin 5 = Neutral
Pin 6 = ( Neg.) 115VDC
Pin 7 = (Pos.) 115DC
Pins and wire colors listed on page 37
Thanks for choosing FixYa,
Kelly
Jan 31, 2011 | Whirlpool Refrigerators
Electric Motor running slow
Century / Magnetek motors are used on many compressors but usually is an upgrade to have the option to easily switch from 110 to 220. Dewalt, Rol Air, Jenny, Emglo and others are considered high end compressors and come with switch for selecting voltage. One still must change the cord if selecting 220v setting. One thing in common is that 115v motors are never more than 2-3 HP because the amp draw for anything over 2hp is likely higher than 20 amps and would trip most common outlet breakers. You noted that your motor sticker lists 6.5 hp at 15 amp 220v so it could not work with 110v because it would draw over 30 amps and just not be practical. Magnetek motors are very good quality and most always state on sticker 110/220v and show wiring diagram for proper connection. Your compressor was most likely built to be stationary and be hardwired into an outlet/switchbox with heavy duty wiring or special cord to run such a high hp motor. You made a great buy however, because the motor alone lists for several hundered dollars alone. You could replace the motor with a 110v but you would loose the fast performance / recovery of that 6.5 hp motor. Like replacing a v8 engine with a 4 cyl. but expect to pull same load, not likely. Good luck with your purchase, and post again if you have other question.
Jul 11, 2010 | Coleman Air Tools & Compressors
Change wiring from 230v to 115v
There should be a wiring diagram on the name plate of the motor, or inside the wiring compartment or on that cover . Would be something with dots and HI , LO, and wire numbers.. or just a notation of 120 , 220 volts.
How is it wired now?
May 10, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Dayton Permanent Split Capacitor Motor Fan Logo
23 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
