Question about Imer Minuteman II - Portable Electric Concrete Mixer
Changing the oil for an Imer minuteman concrete mixer
What kind of oil is recommended for the Imer minuteman concrete mixer
What is the correct ratio for mixing concrete?
generally about 2:3 water to cement. it should say on the bag, if it is too watery add more powder, if it is too thick add more water
Jan 15, 2013 | Building Materials
Leaks oir or grease at shaft where beater attaches
eaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
If you still feel as though the mixer is in need of service, you may locate Kitchenaid certified repair centers through the following link: http://caservice.kitchenaid.com/
Jul 15, 2009 | KitchenAid K45SS Classic Stand Mixer
The mixer leaks oil around the shaft. Is this a user repairable problem? How do I find service centers?
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Jul 10, 2009 | KitchenAid K45SS Classic Stand Mixer
Leaking oil from the main part. Kitchen aid mixer, only used a few times a year
Jul 09, 2009 | Food Mixers
Leaking oil
Jun 27, 2009 | KitchenAid Classic Stand Mixer
Oil Leak-Stand mixer
Jun 18, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My mixer is leaking oil. last time we made bread dough in it it sounded kind of rough. we figured wiyh the heavy load maybe that was the rteason for the noise. when we moved the mixer to clean it, there...
May 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I have a 2002 nissan altima 2.5L with an oil leak but why is the oil always black shortly after a change or fill?
If you are talking about the spot being black on concrete or the oil on the bottom of the engine?
Oil loves dirt also depending on the type of filter you are using will determine the color or how clean your oil is. I recommend using WIX they are not cheap but they do work. After a couple of oil changes you will notice your oil will not appear so black. The black is deposits in the oil.I also recommend using a good brand name oil that won't break down and changing every 3000mi.
May 01, 2009 | 2002 Nissan Altima
K45SS leaks lubricant
Exploded parts views for all mixers are available at www.kithchenaid.com. Click "Customer Care" in the upper right hand corner of the main page, and then select "Locate Manuals and Guides." You will need to enter the unit's model number exactly as it appears on the bottom of the mixer. It will be listed on a white sticker.
Nov 03, 2008 | Food Mixers
Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Jul 24, 2008 | Hobart H600 Stand Mixer
Imer Minuteman II - Portable Electric Concrete Mixer Logo
230 people viewed this question
Top Imer Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Imer Air Tool and Compressor Expert? Answer questions, earn points and help others
